Cooling Removing glued ramsinks
Discussion in 'Hardware' started by SFOD-D LoneWolf, 24 Jun 2004.
  1. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    I wanna remove the stock ramsinks on my ASUS GF FX5900 Gamers Edition, and replace them with Tweakmonster BGA rsm sinks.
    Questions:
    1. How should I remove my old ramsinks without damaging the BGA memory
    2. Is it really worth it?
    I'm gonna flash the card to a FX5950Ultra.
    Cheers,
    Mike
  2. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    if possible, put the ramsinks in a vice and rotate the card sideways
    i use this technique to remove heatsinks from gpu's all the time, works great when there are no caps in the way to get busted...oh well..
  3. slater
    slater Mummy Says Im Special
    18 Apr 2003
    #1. What kind of glue?? epoxy or just weak superglue?? You could try the freezer trick (put it in the freezer and then try and break them off once it has cooled.)
    #2. No its not so dont risk it unless they come off relly easy.
  4. Firehed
    15 Feb 2004
    Well as the memory on a card usually gets a lot of it's heat from the core believe it or not, I doubt it's worth it. Adding them is fine but there's really no sense in changing them.
