Removing M$'s Stupid DRM??
Discussion in 'Tech Support' started by airchie, 16 Apr 2007.
  1. airchie
    airchie What's a Dremel?
    22 Mar 2005
    I know you're all immediately thinking this thread need to be deleted due to the forum rules but its all perfectly legal and above-board.
    My girlfriend's laptop has her entire CD collection on the HDD.
    Ripped using Windows Media Player unfortunately.
    Now the laptop had to be wiped recently due to a virus infestation and it generally needed a really good clean out.
    I did manage to backup the music though before wiping and put it back on after (and after sweeping it for anything nasty).
    Only problem is, Windows thinks the files are stolen or something.
    Keeps saying you can't play them on more than one PC or some such rubbish.
    Obviously, the stupid WMA files have the copyright bit set and the re-install has made them lose their licences and think they're on another PC.
    Is there any way to get them back or do I have to tell her to rip them all again?
    Any assistance appreciated.
    TIA.
    Oh, and if its time to re-rip, is there anything better than CDex or is it still teh daddy? :)
  2. DougEdey
    5 Jul 2005
    According to ye ol' Googleness there are various methods to remove WMA. Unfortunately the legalities of this are circumspect.
    I'd say re-rip as MP3 or FLAC. Much nicer :p
  3. airchie
    22 Mar 2005
    I'm not too concerned by the legalities as my GF has bought the rights to the music when she bought the CDs.
    I had a google and so much of the sites that have apps for download seem dodgy.
    "Here, download and run this exe and everything will be fine". :(
    I'm not even sure it is possible to remove the DRM from the files without the licences on the machine?
    Its just gonna be a mammoth task of re-ripping them all.
    Hehe, would be easier to download them... :D
    Who says DRM protects music?
    Just promotes illegal filesharing. :D
  4. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    Just burn them on to a CD, then take them off. If not, just buy the tracks again, or speak to MS for freebies :)
  5. quack
    quack Minimodder
    6 Mar 2002
    Unfortunately, since you didn't back up the licences before formatting, you will have to re-rip, but don't use WMA this time!
    There is a tool for removing DRM from Windows Media called FairUse4WM but that only works if you have a licence to play the media in question in the first place, so that's out of the question. Burning them to a CD in order to re-rip them is also out of the question, you need the licence to do that.
  6. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    use FLAC to re-rip.
    It is lossless (unlike WMA and MP3) and is quick to convert over to other types.
    If you (or your GF) use an mp3 player, at least rip to FLAC as a digital backup/computer usage and have a separate rip set (or conversion from FLAC) for the MP3 player management program (a la iTunes)
  7. airchie
    22 Mar 2005
    Yeah, I suspect its gonna be impossible to save these files without the licences I deleted during the format & re-install.
    Quack, never before have I so strongly agreed with your sig... :D
  8. airchie
    22 Mar 2005
    What kinda size tradeoff is there for using FLAC?
    Its a laptop and as such doesn't have an abundance of HDD sapce.
    Also, what's the best app to rip CDs to FLAC and/or MP3?
  9. Bluephoenix
    3 Dec 2006
    FLAC has its own ripping program, and/or a plugin for CDex if I remember correctly.
    and the size tradeoff is minimal, I wouldn't use it if it wasn't.
  10. Guest-16
    Guest-16 Guest
    FLAC! or high bitrate mp3 for computability simply because no portable player natively supports flac and getting album art is a pain in the arse :( I need album art for some 200GB of music.
  11. Bluephoenix
    3 Dec 2006
    actually there is a firmware plugin for the iPod that allows it to play FLAC files. but it requires Linux+Amarok
  12. The cheapskate
    The cheapskate One custom title before Matty
    27 Oct 2004
    airchie, you got a pm.
