Modding Removing pins from Athlon XP ?
Discussion in 'Modding' started by sinizterguy, 22 Mar 2003.
  1. SiMonTiST
    SiMonTiST New Member
    14 May 2002
    They are the same thing. :eyebrow:
  2. zackerouac
    zackerouac bring it
    23 Sep 2002
    use a dremel to cut the pins off? :eyebrow:
  3. Tribal Dragon
    Tribal Dragon Insomniac modder!
    17 May 2002
    you need a diamond re enforces drilling bit to drill with a drill... :: cheese :: done it that way....
    I have to get one myself to drill my pentium_75 :D
  4. cderalow
    cderalow bondage master!
    23 Jan 2002
    good idea.... may do that with this TB 1.4 that I've got no idea if it works... suppose i should figure that out first prior to casting it in resin eh?
  5. Pflumingo
    Pflumingo givem the bird.
    17 Jul 2002
    I have a new keychain candidate... Blew up a 2000+ this week...
    This was my attempt at cutting a hole in a P75...
    Pretty hard to cut through the old ones..
  6. Darkness
    Darkness New Member
    8 Dec 2002
    just solder a loop of wire to the pins, instant keyring.
  7. Ubermich
    Ubermich He did it!
    21 Jun 2002
    First, w/ the heatsink (normally) you're just smashing the top of the die.
    With this, you're going all the way through the chip.
    You can smash the chip to bits by hitting it with a hammer, but to get one precise hole all the way through is extremely difficult. Unless you have a really nice drill bit it either A)won't scratch the surface or B)will shatter it.
  8. severedhead
    severedhead New Member
    19 Dec 2002
    would a 'tile and glass' drill bit work?
    im interested in this too, and theyre only £6.98 at b&q
    just gotta try find the drill
  9. I was thinking this too.
  10. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    couldn't you very slowly grind away at it with a stone polisher type thing?
  11. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    the little square in the center, the core/die should be the only real tough part. The stuff the pins are in is an organic sobstrate that carry the BGA connections to pins so it can be used in a socket. This part is a lot like a PCB. A drill should be able to cut through this stuff.
    The core on the other hand, is a silicon substrate (hard, but also fragile) with silicon dioxide grown on it, as silicon nitrides depositied on it. On top of this, tungsten, titanium and molybendum are common metals used to make interconnect structires. That core is a pretty tough little thing.
  12. Digitalblueshift
    Digitalblueshift New Member
    12 Feb 2002
    The newer 'organics' should be piercable by any drill. The older ceramics, like P100's and pretty well anything up till the athlon XP's is unpiercable. I tried Titanium, cobalt, normal metal bits, I tried doing a pilot hole, tried to go straight in with a good sized bit. (incidentally doing a really good job of getting rid of all of the pins.) The only bit I didnt try was a concrete/ceramic bit and that was because the only concrete bit I had was 3/4". But yeah a ceramic bit should work...
    I believe someone around here had one done with an 'Ultrasonic drill'
  13. AW3K
    AW3K New Member
    3 Nov 2001
    You could always do what i did?
    Glue 2 chips together, assumming you have 2 :idea: :eeek:
    then screw a loop in one end.
    Like so
    Enjoy, Just an idea and it hasn't fallen apart yet :D
    Later
    AW3K
  14. Hippo
    Hippo Pre-dates 5.25" Floppies
    7 Mar 2003
    ooh nice idea.
    Ive tried drilling 486 CPU's in the past to no avail :(
    Mebbe i'll give your method a go :D
  15. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    i went strait through a p4 1.3 ghz with a brad point, of course, that different i think. Il have a go at my socket 5 pentium 60 soon.
  16. samuelellis
    samuelellis New Member
    19 Apr 2002
    what i thought was to use a pillar drill & weight the handle so it brought the bit to touching the material but no with too much pressure, then put it on teh slowest speed possible & jsut let it slowly & i men really really slwoly go though but rememberign to put drilling compound by the bit
    the only problem with this is it coudl take hours or even days & you would need to be near the drill while it worked (common sense) & you would need to weight ti in a way that kept the same amoutn of pressure agaisnt the chip right throughout the prcessor
    you would laso need to find away to keep the bit in good health as i actually treid the before, made a dint in a 468 but the brill bit snapped as it go too hot
  17. pheonix
    pheonix Toot Toot!
    14 Mar 2001
    guys guys guys your making faarrrr too much work out of this
    The AthlonXP is made from an organic substrate. This stuff is dead easy to drill though...I just used an ordinary wood drill bit to get through a PIII, which is the same kinda stuff. I don't think he will have problems unless he actually has an original athlon (Tbird), they are ceramic and pretty much impossible to drill through!
    To get the pins off, I just twisted them with a pair of pliers. Worked quite nicely!
  18. Bentos
    Bentos New Member
    12 Feb 2002
    like phoenix said, i had no problem drilling through my XP 1700+, just used a wood drill bit.
    Oh and as for the pins, used wire cutters, then used a file to smooth the whole thing down, not too much hard work really.
    Bentos
  19. y2rock
    y2rock New Member
    11 Sep 2002
    I drilled a hole right through mine using a generic small drill bit and I drilled where one of those small black spacer pads are.
    Bu trust me remove the pins as I havent and I have some nasty scratches to show for it.
    Just thought this might help.
  20. Boggy
    Boggy New Member
    3 Jan 2002
    i did a p166 (it has the organic substrate stuff) nice result, oh yea pulled all the pins out with my leatherman pliers :D
    looks good will get a piccy if u like.
    used a dimond bit on an old 486dx (a lot of them) and they smasghed and then bluntened the drill bit!
    if you can get a hole in one it would be a really crap key ring anyway if you treat ur keys like i do, throwing them around will smash the chip to smitherines, i have have 7 intel pentium (ceramic chips lying around dud) if any one is interested will sell for £2 each ;) (may as well make some profit).
    thebogbrush(at)hotmail.com
