How do you remove an old thermal pad, off the bottom of a heat sink? I'm sure im being dumb so i wondered how do you. thanks in advance
I usually put some rubbing alcohol on it (isopropyl), let it work on the adhesive a big and then gently remove the pad with a clean/sharp razor blade.
I usually use a little Goof Off and my finger nail so I don't have to worry about scratching the heatsink surface. Of course if you are going to lap it that wouldn't matter.
