Basicly I have drawn my sections and elevations and I would like to achieve something like this. Can I do this in photoshop or should I be using a different program the quicker the better. Cheers
If it was me, I would go for sketch up and export a 2d graphic using a modified style which contained, lined edges. Then work the image using the lines as a guide with illustrator and photoshop. There may be easier ways but that's just my work flow for these type of designs
Yes, been there done that, only with concrete (not to bad) and brick (not fun at all) Sectional elevations are actually really quick to do in photoshop, it's when you delve into perspective's that things get a bit more complex, especially with curved faces... Probably, depending on the degree of texture repeatability you're willing to put up with, as most textures would be wallpapered onto the face, who's edges would later need touching up in photoshop. *** Also, snap ED22, same method I use ***
