Modding Renovatio Mark 1
Discussion in 'Modding' started by Phenom, 30 Jan 2016.
  1. Phenom
    Phenom New Member
    26 Mar 2015
    Hello everybody,
    I present to you my new scratchbuild project named " renovatio mark 1 " , renovatio mean renew in latin and why i choose this name ? because the first idea of this project is to create something new but without change the existing things and mark 1 because this is the first bench table i do .
    I tell you the story , there are six months of that, I was looking for a bench table "cheap" but "design" to test the components I had in stock , I found things on the internet but at so expensive prices ... Anyway I decided to imagine a " one is never better served than by oneself " the first goal of the maneuver was to quantify the design of a table custom bench and see once modeled if the project is interesting or not .
    the second objective was " easy integration watercooling ."
    I started in the plans in 3D Solidworks and after six months of planning and testing, I released this:
    Top view : light gray clutter of a motherboard ATX
    Bottom view :
    side view :
    https://lh4.googleusercontent.com/-...-I/AAAAAAAAD5o/O_5u8Vy-b2M/w800-h406-no/4.jpg
    Vue isometrique :
    All gray blocks that you can see inside are the pump and power supply , I plan supports for the pump , radiator, power and SSD, I show you once received .
    The model measures 47.3 cm x 47.3 cm x 15 cm.
    The basic configuration will be unveiled shortly.
    I sent all cut from " johnsteelpro " in France I shall have to do the folds and seams .
    It cost me € 180 including shipping to those interested
    a small dot on the config [ [;)] ] :
    and a sponsor follow me , thank you to " EK watercooling "
    here are the pictures all parts have been folded by a professional " family thank you " I confessed that I had a strong emotion when you see everything taking shape like that while this was an idea.
    here are the photos :
    I'll see if it all could be sealed today.
    See you.
  2. Phenom
    Phenom New Member
    26 Mar 2015
    eheh
    see you.
  3. coalminer071
    coalminer071 New Member
    10 Sep 2015
    Wow, interesting case design. I like it.
  4. Phenom
    Phenom New Member
    26 Mar 2015
    hello,
    I spend tonight bring news , today there is a strange thing happened in my office I decided to give food to my old PSU that was to serve me ... for this mod is that it eats well it's the little beast .
    and boom...
    I'm kidding .
    A big thank you to Bequiet [/ b] for this wonderful participation
    adds that this 4 ventilos Bequiet shadow wings in perfect 120mm radiator for the project .
    - Assembly of all the components is made :
    mother board
    power supply
    SSD
    Pump
    Rad
    Tanks
    switch on/off
    the protection of this switch
    I have a few modifications :
    - Insert one of the tanks is still top of the blow one of them is slightly inclined I retravaillerai tomorrow .
    - The plate of SSD to deliver 90 degrees.
    I also add feet project that I will double in caoutchou to avoid scratching the tables already and to create a slight thickness so that the bolt does not touch the ground.
    I shall have to go up the watercooling but I await news .
    and do the painting , I think based on the green and black " view can be a nvidia logo " .
    to see, unless you have better ideas , I was listening.
    @ see you soon.
  5. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    agree, always like Green / Black color themes
  6. Phenom
    Phenom New Member
    26 Mar 2015
    Finish and coming soon.
    see you.
  7. Phenom
    Phenom New Member
    26 Mar 2015
    hello
    mod is finished !!!
