Displays Replacement capacitor advice
Discussion in 'Hardware' started by Agent_M, 23 May 2012.
  1. Agent_M
    Agent_M Minimodder
    4 Feb 2005
    Recently my monitor back light died and it seems that the capacitors on the power supply have died, they're low quality ones that through googling have failed on other monitors and tvs within a few months.
    Now I know nothing about caps so I need some advice on getting replacement ones, as I don't want this to happen again I'm planning on replacing all of the caps from 'CapXon'.
    The caps in question are rated at:
    330uf 35v
    KF105c
    22uf 50v
    105c
    740uf 35v
    105c
    There are two other caps that seem to be for the back light power which are made by a company called Rubycon, which look fine but should I replace these too?
    Any advice on good replacement caps would be great as I don't really know what I'm looking for.
  2. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    if you are replacing some of the caps, then whilst you are at it, it might be worth replacing the others as well.
    to be fair they aren't that expensive anyway.
  3. Agent_M
    Agent_M Minimodder
    4 Feb 2005
    That's true, do you think its worth replacing the higher quality ones too?
    If I do, there's a bunch of a white stuff on the largest cap sticking it to the board, what would I do about that stuff?
  4. RichCreedy
    24 Apr 2009
    the white stuff is just glue, you can pick at it, you don't have to put glue back on it, just make sure it isn't all over the solder joints.
