Storage replacement drive for NAS
Discussion in 'Hardware' started by RedFlames, 4 Nov 2025.
  1. RedFlames
    23 Apr 2009
    as posted elsewhere... one of the [SATA] SSDs in my NAS has kicked the bucket and i'm mulling over what the best course of action is...
    Current Drives -
    RAID 1 -
    2x Seagate Ironwolf, 4TB [SATA, Spiny rust]
    Raid 1, acting as tiered storage for the above -
    1x Seagate Ironwolf 125, 1TB [SATA, SSD]
    1x Seagate Ironwolf 110, 960GB [SATA, SSD] <-- The Dead Drive
    Why are the SSDs mismatched? well it was originally a pair of 110s, but the first one died and was replaced under warranty with the 125.
    The second, and now also dead, 110 is out of warranty, so swapping it under warranty is out.
    Seagate no longer seem to sell/make the 125, so just buying another one to replace the 110 is out.
    So... if you were me, what would you do?
    Replace the dead SSD and [continue to] live with the NAS moaning about the mis-match
    Replace both SSDs
    Something else.
  2. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    Is the NAS complaining about the different models or the fact that they are slightly different capacity?
  3. RedFlames
    23 Apr 2009
    I mean right now one of the drives is toast so it's whinging about that...
    But prior to that it was whinging about the mis-matched capacity... it wouldn't let me do certain things as a result [like set them as read/write cache, though it did let me use them for tiered storage... which is causing its own problems now a drive is dead]
    All the drives are/were seagate so idk if it'll whinge about mixed makes
  4. meandmymouth
    15 Sep 2009
    You should be fine with different models with the same capacity, so I'd purchase another 1TB SSD. It's generally recommended with spinny rust in particular to mix models anway, prevent ending up with 2 drives from the same batch.
    I have a 1TB SATA SDD lying around if you want me to send it for you to test?
  5. RedFlames
    23 Apr 2009
    No I'm good... just a matter of deciding between a WD Red or Samsun as a replacement now
  6. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Seagate Ironwolf are worth a look too
  7. RedFlames
    23 Apr 2009
    That's what the currents SSDs are... and they no longer appear to be for sale, only the rust spinners... hence the quandary.
  8. Big_malc
    Big_malc Minimodder
    7 Sep 2010
  9. RedFlames
    23 Apr 2009
  10. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    Idioteque likes this.
  11. RedFlames
    23 Apr 2009
    Bit spendier than i'm able to facilitate right now... but i have considered used enterprise fodder in the past...
  12. Idioteque
    Idioteque Telephasic Mongoose
    21 Aug 2004
    3520TBW endurance ain't too bad!
    I mostly use enterprise spinning rust and SSDs for their reliability and cost. It's cheaper to buy in bulk and have some spares on hand. That and with a 15-wide disk shelf I get SSD-like read speeds for large files. Anyway, definitely recommend both enterprise equipment and bargainhardware.co.uk
  13. RedFlames
    23 Apr 2009
    Ambition exceeds budget, and space...
    This 4-bay QNAP is what i have to work with so for now it'll have to do.
