Cooling Replacement H60 fans
Discussion in 'Hardware' started by MightyBenihana, 10 Sep 2011.
  1. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
    H i all,
    I would like to hear from those who have replaced the standard fan on the Corsair H60 - what did you replace it with?
    I would like to replace it with a Gelid Wing 12 for noise reduction purposes, however I want to use the ones without LEDs but it appears that these have a lower static pressure than those with LEDs. Also both fans have a much lower static pressure than the standard fan.
    However if you think that the standard fan is quiet enough, let me know that too.
    Also what minimum static pressure would you suggest for this piece of kit.
    Thanks
  2. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Scythe gentle typhoons are good for rads for their high static pressure and I wouldn't go for anything less than the 1850rpm version as I think the corsair ones are 2000rpm but worse.
  3. MightyBenihana
    8 Sep 2011
    Do you happen to know the static pressure of those as I've heard good things about them but I can find this stat anywhere.
    thanks
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I use GT's on a proper rad and they're really good, so they're what you want really :)
