Electronics Replacement VGA Monitor Cable
Discussion in 'Modding' started by Jabberwocky, 30 Jun 2005.
  1. Jabberwocky
    Jabberwocky What's a Dremel?
    23 Dec 2004
    I have an older 15" monitor that no longer displays the color red, besides that the picture is fine. I'm pretty sure that there are wires in the cable that are damaged, thus preventing it from displaying red. Does anyone know of any websites where I can by a replacement VGA cable with flying leads? Radioshack used to sell them, but I can't find them on there website anymore. I have searched, but I can't find them anywhere. Any help would be appreciated.
  2. pucky124
    pucky124 What's a Dremel?
    15 Oct 2004
    i am not sure what you mean by flying leads but this might help vga monitor connectors are also called male 15 pin d-subminiture (d-sub) for short. this should help your search. also futulec.com and allelectronics.com should be good bets.
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
  4. Ghlargh
    Ghlargh What's a Dremel?
    16 Nov 2003
    No, the gameport uses a 15 pin D-sub, DS15. The VGA connector is a HD-sub(for High Density D-type Subminiature) HD15. Just so noone orders a gameport cable instead of a monitor cable...
