Notebooks Replacing a Celeron M with a Pentium M?
Discussion in 'Hardware' started by Rexxie, 23 Feb 2006.
  1. Rexxie
    Rexxie What's a Dremel?
    18 Nov 2002
    This might be a stupid question, but I was wondering if its possible to replace a Celeron M with a Pentium M in a laptop? Both are Socket 479, right?
    Not sure how much difference they are heat-wise, and if you'd have to flash the bios somehow..
    Anyone?
  2. Guest-16
    Guest-16 Guest
    Depends. The chipset needs to take it (865 versus 915) and the BIOS needs to support it. But I dont see why not.
  3. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    If you get a 400 FSB chip (7x5) then it should work fine :) FSB is the same, might not need a bios flash either...
  4. malfunction
    malfunction What's a Dremel?
    5 Jun 2002
    Run CPU-Z or similar and post back what it reports. The Cele M could be Banias (0.13u, 512K L2) or Dothan (0.09u, 1MB L2) based - which would help decide how much of an upgrade a Pentium M would be over the Celeron M. IMO the best benefit of upgrading (aside from any potential clock speed boost) as speedstep (dynamic underclocking) = longer battery life and a boost in L2 cache (more so for an older Banias / 512K Celeron than a Dothan / 1 MB Celeron). As has sort of been said if the chipset it i855 based it can only take a 400MHz FSB chip. If it's i915 based it should (BIOS permitting) be able to take a 400MHz FSB or 533Mhz FSB chip. In theory anything should work but I believe some laptop manufacturers program the BIOS to only boot with the class of chip the laptop was 'designed' (marketed) to work with.
  5. Rexxie
    18 Nov 2002
    Thanks for the tips guys. I don't have any laptop to try it on at the moment, I was just wondering of getting a relatively cheap Celeron M based laptop that has been offered to me and replace the CPU, if that was possible.
    I'll post my findings if I get to try it out :)
  6. gbeeby
    gbeeby What's a Dremel?
    6 Dec 2005
    i was thold that pentium m require less cooling thats why pentium m laptops tend to be lighter than celeron laptops :thumb:
  7. malfunction
    5 Jun 2002
    Celeron M's have EIST (speedstep) disabled so in theory the Pentium M might be able to run cooler at idle - same reason the Pentium M is better for battery life than the Celeron M too (though I haven't tested this). The increased cache probably makes some difference too (more cache = busier CPU at load = hotter I would have thought but I don't know for sure). TBH I doubt there's much in it and as IIRC all the 'M' chips are rated for ~30W max so most of the cooling solutions would be planned around that so that whoever is making the laptop can put a range of chips in it. I think the lighter / smaller / thinner laptops tend to be pentium not celeron based because they're higher end / more expensive and same goes for cheaper / lighter / celeron based lap tops.
