Networks Replacing Switch Box
Discussion in 'Tech Support' started by stepea, 25 Jul 2010.
  1. stepea
    stepea What's a Dremel?
    13 Dec 2009
    Current system = WiFi Router connected to a switch box in another room as the Wi-Fi signal in that room is poor. I want to get rid of the cables coming out of the switch box. Can I just replace the switchbox with a WiFi router/access point - so I can get Wireless in the other room.
  2. Golygus
    Golygus Minimodder
    9 Oct 2003
    replace it with an access point. you don't need a second router.
    obv. you'll still have a cable between your router and the access point!
  3. stepea
    13 Dec 2009
    Yes I would keep the cable from the router to switch or access point.
    Any suggestions of Access Point, haven't got a lot of cash to play around with
  4. Golygus
    Golygus Minimodder
    9 Oct 2003
    801.11n
    802.11g
    there may be cheaper ones elsewhere, but thats what scan have for access points.
  5. stepea
    13 Dec 2009
    Thanks for the advice, ordered one from scan.
  6. Golygus
    Golygus Minimodder
    9 Oct 2003
  7. stepea
    13 Dec 2009
    one other question I've thought of - can I plug my network cable from the router into the switchbox first and then from the switchbox to the Wireless Access Point - because I've got a couple of things in the other room that isn't wireless.
  8. saspro
    saspro IT monkey
    23 Apr 2009
    Yes
  9. stepea
    13 Dec 2009
    Cheers
