Other Replacing weatherstripping
Discussion in 'General' started by silk186, 10 Mar 2019.
  1. silk186
    silk186 Canadian
    1 Dec 2014
    I locked myself out of my place when I forgot a key on the inside on the door. I have a locksmith bump the lock. I've ordered a thumbturn cylinder and I'm looking to replace the weather stripping. I'm renting so it only needs to last a few years. It currently has 2 pieces or foam stip but it has completely fallen apart. I've done some reading but most refer to the US style of weather stripping that fits into a channel in the door which is not an option for me.
    eBay has a hundred different materials and styles, what should I look for?
    [​IMG] [​IMG]
  2. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    Do you know if the existing foam is an intumescent strip? Eg, for fire regs
  3. silk186
    silk186 Canadian
    1 Dec 2014
    I would assume that is is nothing special. I think the lock is not up to fire code and the smoke alarm was in the wrong room.
