Equipment Requesting some help from some of you BiT photoraphy gurus on my Powershot G9
Discussion in 'Photography, Art & Design' started by bixie_62, 19 Jul 2009.
  1. bixie_62
    bixie_62 Active Member
    17 Jun 2004
    Hi all
    I've got a canon PowerShot G9 Camera and due to some unfortunate mishap, the front metal ring has cracked and as such the lens no longer closes!
    The writing on the lens is
    CANON ZOOM LENS 6x IS
    7.4 - 44.4mm 1:2.8-4.8
    So, i ask you guru's of bit,
    where can i obtain an identical replacement lens for this camera?
    many thanks
  2. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    As far as I know, lenses on the PowerShot line of cameras aren't considered removable, so you'll have a hard time finding one. This being Bit-Tech, I'm not going to tell you it can't be done - we're hardly normal consumers - but even if you can find a lens, it's going to be tricky. You should probably scour eBay for another camera of the same model, perhaps one with a cracked LCD or some kind of sensor issue.
    Other than that, you might take some time to talk with Canon support; I had to get a PowerShot repaired a few years back and they were very helpful. Mine was apparently covered by a recall, so I don't know what your issue might cost, but it's certainly worth asking.
  3. bixie_62
    17 Jun 2004
    Cheers for your input Crazybob
    I had a closer look at the camera, and theres a button which when released allows an 'o' ring to be unscrewed at the base of the lens
    basically, the top o ring with writing on it that holds down the 'shutter' bit that opens and closes when you turn the camera on/off is busted and needs to be replaced somehow but i cant figure out how to get it off to repair it
    cheers
  4. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    I'd still be talking to Cannon support about this, attempting to fix it yourself will void warranty. Otherwise, I couldn't find a service manual for the G9, but did find some photos of the G7 being dismantled. The cameras are visually almost identical, so it may be some use:
    http://qman.fotokala.ee/Kaamerad/PowerShotG7/index.html
  5. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    Take it to a Canon service center. Fixing it yourself has an almost 0% chance of working and you'd be breaking a great camera even more. Show some respect to a beautiful design.
    Edit: if you are talking about the knurled ring at the base of the lens, then that is for the attachment of lens modifiers.
  6. cherryme
    cherryme New Member
    26 Jul 2009
    We provide almost everything for EVE-Online
    www.items4eve.com
    items4eve.com
    We provide almost everything in EVE-Online , free delivery in 30 minutes, nice customer support here. Come on and enjoy your wonderful shopping 
    Exhumers Ore Hulk Caldari Battleships Raven Navy Issue Full Set Of +5 Improved Implants Gallente Battleships Megathron Navy Issue Gallente Freighters Obelisk Caldari Battleships Raven Capital Industrial Ore Rorqual Caldari Battlecruisers Drake Minmatar Heavy Assault Ships Vagabond Angel Battleships Machariel Gallente Battleships Megathron Caldari Navy Cruise Missile Launcher Energy Grid Rigs Capacitor Control Circuit II Advanced Anti-Ship Rockets Phalanx Rage Rocket Advanced High Precision Light Missiles Bloodclaw Precision Light Missile Standard Auto-Targeting Hydra F.O.F. Heavy Missile I Standard Auto-Targeting Eradicator F.O.F. Heavy Missile I Advanced High Precision Light Missiles Bloodclaw Precision Light Missile
    www.items4eve.com
    items4eve.com
  7. cherryme
    cherryme New Member
    26 Jul 2009
    www.items4eve.com
    items4eve.com
    www.items4eve.com
    items4eve.com
