Well i just got my new res for my project but now im pissed off. For one thing, it came all scratched up and looking like crap and two, its way bigger than the site said it was. (now that im starting to rant, theres this stupid l orange flow meter in it too, also beacuse ive been waiting since august for them to be in stock). So now that this thing is way too big and Im gonna have to re-desing where it could go, should i just send it back and use my fill-port with no res? So just restating the question: Should I have a res or just use my filport? Please help! Edit: I just thought how about a dual 3 1/2" res turned sideways in my lian li pc-65's harddrive rack in the first slot? Know of any with led holes so i can light it up?
Well thats another thing, The res is too big because the site that i bought i from gave the wrong dimentions so it dosent fit my case anyway. So now my new question is: Dual floppy bay res or no res at all? Edit: and i did find a floppy bay res with the led holes
hmmm... I suppose you're not going to use the floppy bays anyway... and a res will help in removing air and there is allways some little evaporation and the res fixes that... and there are some other benefits with a res aswell...
Yeah i took the 3 front ones out for my ps1 screen and i only need 2 of the 5 in the rack for hardrives, so I will have one left for expansion.
ml are the same as cm^3, so just take the dimensions of the particular res you're looking at in cm (I imagine the volume varies between different res's), and multiply them all together, then you get your volume in ml. A res is mainly there to help bleed the bubbles out of your loop, and to look pretty. The size doesn't make much difference.
