News Researchers claim major LCD breakthrough
Discussion in 'Article Discussion' started by bit-tech, 4 Jul 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    So will that solve the contrast issue with current LED backlit (non OLED) screens?
  3. Gareth Halfacree
    4 Dec 2007
    They claim a wider colour gamut, so it'll certainly improve things - but you'll still have the problem of a backlight shared by the whole display (or, for the clever zoned versions these days, large chunks of it.) Per-pixel lighting OLED-style is still your only choice for truly sharp contrast - well, that or going back to good ol' CRT, anyway.
    EDIT: Though, I guess in theory, if you're no longer blocking 70% of the light with colour filters you could add a coating to the screen that blocks more of the backlight - and that might make your blacks blacker while still giving you decently bright colour, which would otherwise be the problem with that approach.
  4. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    Sounds a bit like a "solid state" DLP crossed with LCD...
  5. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    AIUI this requires backlights to exclusively use fully independent R, G and B emission elements. This was a backlight solution abandoned at least a decade ago due to cost, size, and power consumption, in favour of white emission LEDs (and more recently, monochrome LEDs combined with Quantum Dots to provide the rest of the spectrum from stimulated emission). Switching back to RGB backlights with QD assistance (to achieve the gamut now demanded) would mean needing a backlight array (or backlight entry to the distribution film) that keeps the individual LEDs optically independent (to prevent them stimulating emission from the QDs of the other channels due to backscatter) and adding filters to remove the driving wavelength for the channels that do not require it (driving wavelength is usually blue to its higher energy. It;s easer to stimulate green or red - lower energy - emission with blue than vice versa).
    Colour-sequential displays are completely unsuitable for VR, due to temporal chromatic fringing. On top of that, FLCD cells do not have variable transmissivity like TN LCD cells do, they are either off or on. That means brightness modulation is only via PWM rather than direct emission control, causing further issues for VR (which needs low persistence driving rather than being able to average output over a whole frame).
    FLCD is the technology used in LCoS panels. The new development here is not the display technology itself, but being able to fabricate larger panels economically.
  6. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    Isn't there an extra 'd' in there?
  7. Gareth Halfacree
    4 Dec 2007
    There is indeed - fixed, ta!
  8. David
    7 Apr 2009
    ten times the price :lol:
    jb0, Big Elf, MLyons and 1 other person like this.
Tags: Add Tags
