News Researchers crack 768-bit RSA
Discussion in 'Article Discussion' started by CardJoe, 13 Jan 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. yuusou
    yuusou Multimodder
    5 Nov 2006
    If it's man-made, it's breakable. Meaning, if it's an algorithm created by people, even if calculated on a computer, it's reversible. Also, 1500 years? Quite crazy honestly, with so many people poking around into breaking codes.
  3. OWNED66
    OWNED66 What's a Dremel?
    2 Sep 2007
    WHAT 9000 ?!?!?!
  4. cjoyce1980
    cjoyce1980 What's a Dremel?
    17 Jul 2007
    LOL!
  5. Psytek
    Psytek What's a Dremel?
    23 Dec 2008
    Compared to the recently discovered exploitable flaw in SSL, this isn't actually the biggest threat to SSL security. A hacker is rarely going to brute force an attack if there is an easier alternative.
    http://wiki.twit.tv/wiki/Security_Now_223#The_Latest_SSL_Exploit
  6. biebiep
    biebiep What's a Dremel?
    12 Dec 2007
    =>Everything<= is crackable with Brute-force.
    Given time and loads of computational power.
  7. p3n
    p3n What's a Dremel?
    31 Jan 2002
    Man in the middle seems very far fetched with the routing involved in the internet (you would imagine it would require phsyical access to a 'secure' datacenter/edge router)
  8. Digi
    Digi The not-so-funny Cockney
    23 Nov 2009
    This is true but your statement is misleading. If it takes 1000 years to brute force a code then it's a little unfeasible for a hacker to want to do so, wouldn't you say? :p
    Interesting article though... however I wonder if it's more a case of holes and exploits in software that are more likely to be the threat nowadays as mentioned by a poster above. Whats the point in breaking down the front door when the window is unlocked.
  9. Hugo
    Hugo Ex-TrustedReviews Staff
    25 Dec 2006
    I'm pretty sure the majority of 'hackers' don't have access to a supercomputer cluster, and any that do aren't likely to waste their time intercepting my SSL traffic (It makes much more sense to target a larger repository of data than a single web transaction). More likely they'll be hacking Google.
    That depends. 1,000 years with an 'average' computer isn't off-putting if you have a botnet.
    Dirty maths: 1000 x 365 x 24 = 8.76 million = the number of 'average computers' required to crack a "1000-year" encryption in an hour - not out of the realm of feasibility I would posit.
    EDIT: Someone correct me if I'm over-simplifying please.
  10. specofdust
    specofdust Banned
    26 Feb 2005
    Botnets are ordinarily in the range of hundreds of thousands tops, not millions. You're looking at days or weeks even with a botnet I'd guess.
  11. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    between the sieving and matrix runs took them 15 days on the array (10 day sieving and 5 on the matrix).. least in the pdf what it says- 1024 bit is still out of reach for the next 5 years, think they want double checks in the future and go from there
    that's pretty cool research =] guys are all into it..
  12. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    How many souped up PC's is a "cluster".
    Tens, hundreds or thousands?
  13. Neophyte4Life
    Neophyte4Life What's a Dremel?
    24 Feb 2009
    Especially now when you have machines like the FASTRA. Get a few of those and you can do a lot of kinky things with pi. Just not while you are playing crysis......
  14. Flax
    Flax What's a Dremel?
    24 Jun 2002
    This is a non sequitur. Public key algorithms are valuable because they allow you to verify the security of a communication without exchanging keys in advance. This is important because transmitting keys over an insecure medium (such as the net, phone system, postal service or any situation where you cannot guarantee privacy) is dangerous and because maintaining separate keys for every party you wish to communicate is impractical.
    Two factor authentication simply means replacing a password with, for example, a password and a iris scan. "Something you have, something you know". The main point of this is to make it harder for idiots to compromise their own authentication credentials (by writing them down) or to prevent people from intentionally sharing their credentials.
    This bears no relevance to the security of RSA because the attack does not rely on the user giving an attacker access to their key but rather allows the key to be factored from the encrypted data.
    This also has nothing to do with the security of RSA and is a pretty dubious claim anyway.
    Andy Cordial is either being misquoted in the original article or is completely clueless about cryptography. Origin Storage sell the sort of pin-protected hard drives he is recommending, so take what you will from that.
    In regards to the actual news story, while academically interesting it isn't a big deal from a security standpoint. 1024 bits was a short key in 1995. Anyone actually using a 768 bit key doesn't care about security.
  15. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    RSA has always been about keeping the key-length in the area between what's feasible to compute for encryption/decryption and what's feasible to brute-force. As computing technology gets faster and faster (see Moore's law), small keys will continue to get broken - it's the natural evolution of technology.
    Note, however, that RSA is NP-complete: there is (so far) no silver bullet to make cracking it any faster than the brute-force approach. Double your key size, you'll be fine for the next several years. When they get close to cracking that, double it again, and you'll be fine again.
    Tl;dr: Meh. RSA is still good, just increase your key length.
  16. LucusLoC
    LucusLoC What's a Dremel?
    28 Nov 2006
    this is pretty neat. they actually broke the math, not the programing.
    while it is pretty amazing that they found a fast way to factor RSA i agree with both flax and techno-dan. 2 factor authentication has nothing to do with data encryption, and when your RSA key gets too short just make it longer.
  17. Bede
    Bede Minimodder
    30 Sep 2007
    I am so disturbed :D
  18. eddtox
    eddtox Homo Interneticus
    7 Jan 2006
    Whoa, now that is big news! +1 rep
    I was thinking along the same lines. ] wonder what they mean by "average" computers these days and how they would compare to the Bt folding rig, for example.
  19. dec
    dec [blank space]
    10 Jan 2009
    if all the folders in the world went on a brute force attack they could prolly do it in a couple days or so.
    +1 to SSL having bigger problems than 768 bit encryption.
    So in 2030 SSL should be at what 16000-bit?
  20. Horizon
    Horizon Dremel Worthy
    30 May 2008
    meh, 365,000 computers and day > 8.76 million computers and an hour
Tags: Add Tags
