News Researchers create ultra-thin battery
Discussion in 'Article Discussion' started by julieb, 22 Sep 2010.
  1. julieb
    julieb What's a Dremel?
    12 Aug 2010
  2. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Sounds cool. But a slim phone/gadget is not my idea of "best use".
    I'd forget it was in a pocket and lean on it, I expect.
  3. Mraedis
    Mraedis Minimodder
    5 Sep 2009
    I can only wonder how long those will last, and by that I mean both battery life and time before something breaks.
  4. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Sounds like the disposable mobile phone is just around the corner....
  5. Mentai
    Mentai What's a Dremel?
    11 Nov 2007
    Looking forward to the iScroll.
  6. wyx087
    wyx087 Multimodder
    15 Aug 2007
    that flexible Nokia phone concept anyone?
  7. Krikkit
    21 Jan 2003
    Never mind a flexible device, what about a battery that gets painted on the inside of the casing of your mobile or laptop?
  8. tom9383
    tom9383 What's a Dremel?
    21 Sep 2010
    mnnnnnn... electric cars...
  9. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    The question is how many volts at what amperage and how long does it last before recharging.
  10. SteveU
    SteveU Minimodder
    19 Jun 2009
    Lol, like they're not already?!?!?
  11. Xir
    Xir Modder
    26 Apr 2006
    a "higher energy densitie than existing thin battery types" good wording, in other words, probably not comparable to non-thin batteries.
    You're right, it needs an application to rock my boat.
  12. paisa666
    paisa666 I WILL END YOU!!!
    4 Mar 2009
    meh, they do something thin and you instantly think in even thinner devices!!
    just improve the technology, then take 20 of this and put then together to make a smartphone that actually last enough to make calls and watch videos or movies while traveling and videoconferencing, all in one charge, there, that's a good use of the technology
  13. MajestiX
    MajestiX What's a Dremel?
    14 Apr 2002
    now paper not only cut you but will taser you at the same time.
  14. eddtox
    eddtox Homo Interneticus
    7 Jan 2006
    I'm with paisa666 on this one. It may well help move existing batteries on
  15. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    :thumb: Good catch on the wording there.
    :idea: If you put this in a flexible device and combine it with something that would charge the battery when flexed ... I wonder how long before that gets patented.
  16. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    Cool so we will see throw away paper phones like on Ultra Violet and ePaper like we see on Caprica. Now that would be cool.
  17. ZERO <ibis>
    ZERO <ibis> Minimodder
    22 Feb 2005
    I just hope this means that if I use this to make a battery the same size as one that exists now it will store more power...
  18. Farting Bob
    Farting Bob What's a Dremel?
    21 Jan 2009
    No, your comparably chunky phone battery will probably last longer than a battery as thin as paper. Thats just common sense. But you can stack paper on top of eachother, and suddenly youve got a battery the same size as your current one but providing much more power.
  19. deadsea
    deadsea What's a Dremel?
    9 Oct 2009
    Eh... Energy density my friend, energy density. Less power per unit volume = less power at any volume. Think wood blocks vs lead blocks.
  20. Xir
    Xir Modder
    26 Apr 2006
    Considering "normal" round batteries (like AA or AAA cells) consist of rolled material as well, I think they'd have worded it differently if they could compete with that and not with "existing thin battery types"
    But maybe they'll surprise us
Tags: Add Tags
