News Researchers tip reversed LEDs for cooling breakthrough
Discussion in 'Article Discussion' started by bit-tech, 14 Feb 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Alecto
    Alecto Minimodder
    20 Apr 2012
    This works because basic physics (as long as LED generates some current, it is "soaking" up photon energy from its surroundings, thereby cooling them). As long as energy absorbed is moved (and dissipated) somewhere else this provides localized cooling effect.
    But here's a thing: one can move even more energy using phase-change in refrigerant. I don't think my AC has 1 sq. meter evaporator, yet it can pump kilowatts worth of energy continuously.
  3. Gareth Halfacree
    4 Dec 2007
    But is your air conditioner both solid-state and the size of a grain of rice? 'cos this is.
  4. IamSoulRider
    IamSoulRider Minimodder
    24 Aug 2016
    FInally a use for RGB???
    jb0 likes this.
  5. Alecto
    Alecto Minimodder
    20 Apr 2012
    By the time this scales up to pumping 3.5 kilowatts of energy from hot side to cold side it's not the size of grain of rice either. The hypothetical figure they are hoping for at some point in the (distant?) future is 1 kilowatt per square meter, provided that tehy somehow figure out a production process that allows for that sub 10 nanometer spacing.while simultaneously depositing over extremely large area (far in excess of semiconductor wafers in use these days) ...
    Chances are that a LED layer introduces enough thermal resistance for all the benefits of such cooling to be offset by it and that a simple finned heatsink with perfect mirror-polished sub 10 nanometer gap would be able to dissipate more heat per area.
Tags: Add Tags
