News Researchers tweak a virus into building phase-change memories
Discussion in 'Article Discussion' started by bit-tech, 6 Dec 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Looks like a great way to produce bulk nanowires, but you still need a way to actually lay those nanowires into a useful structure (same way a big block of Silicon is not a CPU, patterning is the hard part).
    There's that whole "Optane" thing that seems to have enough demand to sell every chip produced...
  3. Gareth Halfacree
    4 Dec 2007
    If only Optane was phase-change memory, you'd have a point. To quote Wikipedia: 'Intel has stated that 3D XPoint does not use a phase-change or memristor technology.' (It does go on to say 'although this is disputed by independent reviewers,' but if Intel says it ain't PCM that's good enough for me.)
  4. edzieba
    14 Jan 2009
    Yeah, Intel and Micron can claim that the 3D xPoint is totally-not-PCM, but if it walks like an Ovonic Memory Switch, looks like an Ovonic Memory Switch, quacks like an Ovonic Memory Switch, came from a company owning the IP to the Ovonic Memory Switch, and is fabricated on the obtuse Chalcogenide process, I'm going to call it an Ovonic Memory Switch.
  5. The_Crapman
    5 Dec 2011
    Another technology 'predicted' by Star Trek.
Tags: Add Tags
