Windows Reset my PC?
Discussion in 'Software' started by Darkwisdom, 9 Feb 2016.
  1. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    Quick question. Basically my PC is getting pretty bogged up with crap I don't use or have forgotten about. Very little is actually precious information (any pictures and videos etc are backed up on an external drive and the cloud). I want to reset Windows 10 from scratch, no information. I have an SSD with the OS and a 2TB drive for mass storage. If I use Win10's 'reset this pc' option, will it clear out everything and will I expect any caveats with this?
  2. jinq-sea
    15 Oct 2012
    I'm guessing this is similar to SysPrep? There are others on here who use SysPrep quite frequently - hoping that someone like Shirty will chime in :thumb:
  3. Darkwisdom
    27 Aug 2011
    I don't think I worded it properly. Basically I wanted to clean install. Is this achievable within windows, using a process that isn't completely convoluted?
  4. phuzz
    phuzz This is a title
    28 May 2004
    Yep, it does a clean install. You keep your files, drivers and updates, but everything else is removed.
  5. jinq-sea
    15 Oct 2012
    Well there we go - every day's a schoolday!
  6. Fetchy
    Fetchy What's a Dremel?
    9 Mar 2016
    only c drive data is cleared, hard drive data is safe.
