Modding Resisance formula??
Discussion in 'Modding' started by Toric, 13 Feb 2002.
  1. Toric
    Toric What's a Dremel?
    29 Jan 2002
    How would I get the output voltage after placing a resister in the line?
    For example: 12v in plus resister (### ohms) = ##v out
  2. relix
    relix Minimodder
    14 Nov 2001
    I'm sure linear will come down here and post the formula here, but in the meantime, you can also check the "electronics" forum, in there there's a sticky thread with the formula in
  3. Geek
    Geek What's a Dremel?
    21 Nov 2001
    Ohm's law, baby! V=IR. Combine it with Kirchoff's loop rule to get:
    V(after) = V(before) - I*R
    Gordon
  4. brutal
    brutal What's a Dremel?
    7 Nov 2001
    i made a resistance calc, a resistor color calc, a resistor chart listing all the values make and a ohm calc on my page: http://www.brutal.tk look under Electronics Calculators
  5. macroman
    macroman The One
    3 Sep 2001
    To calculate the resistor you need to know the current. Without a current the voltage will still be 12V.
    Formua as above
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Might be easier basing on the resistance of the load (as I is not the rated I), then
    New load voltage = 12 * load resistance/(load resistance + resistor value)
    And load resistance = 12/rated current at 12v
    or 144/Rated Power
  7. FeebleUK
    FeebleUK What's a Dremel?
    22 Jan 2002
