Resizing a partition?
Discussion in 'Tech Support' started by boiled_elephant, 12 Nov 2007.
  1. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    My HDD is 150Gb, but the main (and only) partition is only 127Gb. Is there any way to reincorporate the extra space, or would I need to reformat?
    (and if not, will formatting the empty space as an extra drive mess my OS up? I've heard bad things about multiple partitions.)
  2. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    Oddly enough, I've never tried to combine partitions, but I've never had an issue with having multiple partitions, in fact I've had 2 partitions for a bit over 6 months now with no issue, and at other times have had dual-boot setups and single-OS multiple partition setups without issue using Windows XP, Vista and Ubuntu 6.06 and up.
  3. cosmic
    cosmic What's a Dremel?
    6 Jul 2007
    Multiple partitions on hard rives are not unusual - not sure what there is to worry about ?
  4. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Your running XP sp2 yes? That sounds remarkably like the LBA issue earlier windows versions had
    You may have something funky going on in your bios.
  5. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    Can't you resize it in Disk Management?
    Right-click 'My Computer' > Manage > Storage > Disk Management :idea:
