Windows Resizing Partition
Discussion in 'Software' started by Stompy, 27 Feb 2005.
  1. Stompy
    Stompy What's a Dremel?
    16 Aug 2004
    Is there a way to resize a partition?
    On the PC i build for my uncle, it turns out 5gb isnt quite enough for windows, and it keeps complaining about lack of space. Is it possible to steal a gig from another partition and attach it to this one?
  2. unrealhippie
    unrealhippie What's a Dremel?
    24 Jul 2004
    partition manager would do it I believe.
  3. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    Only with something like PartitionMagic.
  4. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Yeh, but like the other guys have said you will need a 3rd party app, like Partition Magic to do it.
  5. Atomic
    Atomic Gerwaff
    6 May 2002
    Yup is the be all and end all.
    Make sure you have v8 or above if your dealing with large disks tho (160GB+)
  6. Stompy
    16 Aug 2004
    Where can I get this from?
    All I can find on the Symantec website is a demo version that doesnt actually do anything
  7. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Unfortunatly there are very few free apps that do this, most you will need to pay for.
  8. Go4t
    Go4t i
    13 Dec 2003
    if you have a knoppix cd you can boot that up and use qtparted
    its a partition magic clone that i find works very well
  9. Veer
    Veer What's a Dremel?
    3 Dec 2004
    ms dos should be fine, prior you know the commands.
  10. tk421
    tk421 Idiot.
    15 Jan 2002
    easier solution:
    mount the documents&settings folder to a seperate partition, and make a 2gb partition at the end of the drive (or better yet, on a 2nd drive) just for the swap file. windows itself only takes up about 3gb at most. the compaints are coming most likely from 2 places : temp intarweb files, and the swap file.
