resolution problem with vista
Discussion in 'Tech Support' started by sotu1, 1 Dec 2007.
  1. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    hery guys, not a serious problem, but is there any reason why vista is telling me my maximum resolution is 1280 x 1024? This is for my desktop, I got a 8800gts and a 21" screen, so surely it shouldn't be a problem running at higher res? Similarly, i'm finding my games aren't giving me any higher resolutions to play with. Maybe the games are capped at similar resolutions but I was sure that I could go higher when i was on XP.
  2. GoodBytes
    20 Jan 2007
    Tell Windows, to show hidden resolutions.
    I would like to tell you where exactly to do this, but I don't have Vista yet...
    in WinXP, you go to the display properties, then go to the "Settings" tag > "Advanced">"Monitor" tab, then uncheck the box "Hide modes that this monitor cannot display"
  3. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    how is the monitor detected by windows? it may just be showing up as a plug & play monitor. Have you looked for any drivers for it?
