Xbox 360 Resolved: (PS3 also) Trying to figure how to plug in PC speakers
Discussion in 'Gaming' started by oscy, 3 Jan 2014.
  1. oscy
    oscy Modder
    22 Sep 2011
    My new TV/monitor's speakers aren't as good as my PC speakers. The TV has an 'audio in' socket (for PC/DVI), but no 'audio out' or headphone socket. It does have L and R audio sockets in the component bit though. I would like to plug in regular ol' PC speakers with the green end.
    Is plugging the PC speakers into an RCA cable, and then the RCA cable into the audio sockets of the component section of my TV, what I need to do?
    EDIT: I bought this: http://www.ebay.co.uk/itm/131068619252?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
    Didn't work. The male for the PC speakers doesn't go all the way in. Very quiet sound can be heard, but not above the major buzzing noise.
    EDIT: I bought this: http://www.ebay.co.uk/itm/321050458174?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
    I'm only getting sound out of one speaker though, not both.
  2. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    This
    Into this
    Into L and R out sockets on the TV will do it
  3. Krikkit
    21 Jan 2003
    Yep. On PS3 you can enable multiple outputs for sound, so you can connect via HDMI to a TV/monitor, then use the old-style "Multi AV" cable to output to two phono's.
  4. oscy
    oscy Modder
    22 Sep 2011
    Are you saying connect an AV cable to the PS3, and then connect the audio parts and the speakers into a female-to-female RCA? (btw Xbox 360 can use AV and HDMI together as well, just remove the AV cable case with a knife so it fits when the HDMI cable's also in. Nice scam Microsoft have got going there)
  5. Krikkit
    21 Jan 2003
    Yes, in your case you could use a Female RCA to 2.5mm female adapter to connect it up to your speakers. In my case it just connects straight into a separates amp, which has the usual RCA inputs.
  6. oscy
    oscy Modder
    22 Sep 2011
    This is what I bought: http://www.ebay.co.uk/itm/131068619252?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
  7. sandys
    sandys Multimodder
    26 Mar 2006
    Alternatively you can do optical out for PS3 and 360 to an amp for audio, Or optical out from your TV to your audio reciever>?
  8. oscy
    oscy Modder
    22 Sep 2011
    Just have PC speakers.
  9. ARM
    ARM Minimodder
    15 Sep 2004
    I don't have a PS3, I'm answering the questions based on Smiffydude's reply.
    Looking at Smiffy's connector, it is a female 3.5mm stereo jack (to which you connect the green jack into) and two male RCA jacks to be connected to the TV.
    The item you bought is a female RCA, which is why the jack does not fit in fully.
    You need to get the connectors as shown by Smiffys'.
  10. jinq-sea
    15 Oct 2012
  11. oscy
    oscy Modder
    22 Sep 2011
  12. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    The clue is in the title:
    You'll need a stereo one.
    Edit: Any one of these is what you need:
    http://www.ebay.co.uk/itm/3-5MM-STE...ion_Audio_Cables_Adapters&hash=item43c42e5cd6
    http://www.ebay.co.uk/itm/3-5mm-Ste...ion_Audio_Cables_Adapters&hash=item5d3eb29605
    http://www.ebay.co.uk/itm/3-5mm-Ste...ion_Audio_Cables_Adapters&hash=item233166d8a2
    http://www.ebay.co.uk/itm/STEREO-RC...ion_Audio_Cables_Adapters&hash=item3cb68e1e17
  13. oscy
    oscy Modder
    22 Sep 2011
  14. adzc1987
    adzc1987 Minimodder
    19 May 2011
    Are these outputs? If not then plugging anything into them wont work. If the TV has no sound outputs then you need to interrupt the sound when it comes out the console.
    How do you connect the consoles to TV, YrbRPr? HDMI?
    Smiffydudes answer only works if the L and R on the back of the TV are outputs.
  15. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    If all the tv audio connections are inputs then something else has to output the sound, like on mine I have a dvd player linked to speakers...but that's only good for watching a film.
    For tv I would need and external hd freeview box with audio outputs linked to speakers.
    I too have a crap tv why would they make a tv with rubbish sound and have no audio outputs......what chimps made that decision.
    Not familar with consoles but I remember my gamecube had component audio this would need to be connected to an amp +speakers eg. a stereo with componets should work.
  16. oscy
    oscy Modder
    22 Sep 2011
    I got the right cable in the end.
    It goes Console - AV cable -> Red and white ends into two female ends of converter cable - speaker cable into other end (which is also female) <- speaker cable - speakers
