Restoring Partitions? HELP!
Discussion in 'Hardware' started by OneSeventeen, 20 May 2002.
  1. OneSeventeen
    OneSeventeen Oooh Shiny!
    3 Apr 2002
    Being the intelligent person I am, I have removed a partion on my hard drive.. (the only partition on the hard drive)
    Which means I got rid of 30 gig of data in less than one second. Any advice is greatly appreciated!!!
    (2500 songs, my first few 3d animations, all my digi pics of my fiancee and I.. gone :cries: *sniff*)
  2. bAnTAi
    bAnTAi What's a Dremel?
    19 May 2002
    hmm....dont know much on the subject...but you gotta rebuild your index....regedit or something....i'll see what i can find
  3. herbs
    herbs Nobody but us chickens
    7 May 2001
  4. FreakOnALeash
    FreakOnALeash What's a Dremel?
    16 May 2002
  5. dakar
    dakar What's a Dremel?
    6 Mar 2002
    If you only removed the partition with fdisk you may be able to just re-create the partition and your data may still be there.. i've done this inadvertantly a few times and using Linux fdisk i was able to recover the partitions and all thier data. But even M$'s fdisk can work. Try it you may just get lucky.
  6. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    if youre desperate try using somethin like pqmagic...might get some better attention in software....
  7. bAnTAi
    19 May 2002
    does pmagic work from DOS??
  8. felix the cat
    11 Jan 2002
    erm...yes but why use dos if one has windows??
    might need an old version though....
  9. bAnTAi
    19 May 2002
    i htought he'd lost windows....isnt this the point? He only has 1 partition and has lost it
  10. Lazy
    Lazy Meow?
    13 Nov 2001
    if you have no windows put in a system/startup disk and this should load fdisk. You can use fdisk the then re-create the partition.
    If you have windows then you can download a "trial" version of partition magic 7 from kazaa. You can then use this to make new partitions.
  11. bAnTAi
    19 May 2002
    what ever you do....dont write anything to your disk....this will lose it all....i found out the hard way last year :sigh: :sigh: :sigh:
  12. felix the cat
    11 Jan 2002
    this is what calls for the BACKUP cd....we all have all these fancy cd writers...use em....
  13. bAnTAi
    19 May 2002
    its true, cd writers were invented to back up.....people like us just abuse them to rip and burn music and games!!!
  14. bAnTAi
    19 May 2002
    although its alright telling you this now!!!! A bit too late i fear
  15. OneSeventeen
    3 Apr 2002
    small update
    Okay, here is the plan, I've got an extra 75 gig drive that doesn't work too well, but it works well enough to install windows, and I've got a copy of XP lying around, so I'll try that temporarily, then I'll load FDisk, and I am supposed to just create a partition on my secondary drive (the one I messed up)?
    There is no restore, just create a new one, and hope it works the same way as my old one.. right? Please let me know before I do this, yes or no...
    (btw.. I'm in a 1 bedroom appartment w/4 people until a week or two from now, so not much space to work... it may be a while before I reply back with Yeah, it worked!!! woot!, or, crap...)
    thanks for all the replies!!!!!!!!
  16. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    You arn't gonna be able to restore that partition if anything is written to that drive.. And you'll need a third party program to pull it off to boot.. Try going to download.com and doing a search for "data recovery" or "restore partition"
    youll find dozens of tools for the job..
    good luck
    -scoob8000
  17. Lazy
    Lazy Meow?
    13 Nov 2001
    use a low level format programme to wipe everything off the drive. Then use fdisk to make a partition. The when you install xp you can make it convert the file system to ntfs.
  18. felix the cat
    11 Jan 2002
    theres another thread around here somewhere with some links to some recovery programs...whatever you do, dont fdisk that partition until you run one of those programs...
