Other RGB "Gaming" HDMI Cable Anyone?
Discussion in 'General' started by Mr_Mistoffelees, 16 Apr 2020.
  1. Mr_Mistoffelees
    Mr_Mistoffelees The Rotary Cat.
    26 Aug 2014
  2. Vault-Tec
    30 Aug 2015
    Gaming? no. However, if the colour can be set it would make it much easier for people who continually have to remove and replace cables. IE if you have say 6 monitors in an array it would make troubleshooting much easier if the cables were all colour coded. Not that you couldn't do that without labels but yeah, I can see some non gaming uses for such a technology.
  3. Guest-44638
    Guest-44638 Guest
    What V-T said... RGB-ing cables for S&G is taking unicorn vom. to ungodly levels...
    Mr_Mistoffelees likes this.
  4. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    That would be super useful to light up all the insides of my cable wrapping.
  5. silk186
    silk186 Derp
    1 Dec 2014
    Colour-coded cables are the only reason I can see for this. Especially as most people try to hide cables.
    That said, I don't need RGB for colour-coded cables. A glowing cable coming out of the back of my TV would be an eyesore.
  6. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    If you want colour-coded cables, I can think of many better and cheaper ways to achieve it than buying a $100 RGB cable...
  7. adidan
    25 Mar 2009
    Jog on Vivify.
  8. MrP
    MrP seeking inspiration
    5 Jul 2007
    Didn't ltt do a video on an rgb hdmi cable?
  9. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Was I the only one that got the sense the writer of the article was more excited about the cable including a optical converter allowing for greater cable lengths? Man I wish the TOSLINK idea had caught on and expanded into video cables. We could have the tiniest cables every.
    Arboreal likes this.
  10. Guest-44638
    Guest-44638 Guest
    Think it was Kyle/Bitwit...
  11. MrP
    5 Jul 2007
    Nope, LTT
  12. Dr. Coin
    13 Sep 2013
    Not he most faltering photo of Linus, he looks like he could just about be collecting his pension checks.
  13. Guest-44638
    Guest-44638 Guest
    I remember what Bitwit reviewed... RGB PSU cables/extensions.
