A/V RGB+HDTV=Fat lot of nothing
Discussion in 'Hardware' started by Pezboy, 29 Dec 2004.
  1. Pezboy
    Pezboy What's a Dremel?
    12 Oct 2003
    I've been trying to connect my pc to my Zenith 27" HDTV (model c27v22) via a 15-pin rgb/vga cable. I've tried different resolutions from 640 to 1024. The manual says "set top box to 640x480p." This is apparently for EDTV. Evertime I connect the PC and turn it on, the TV says "PLease connect a valid video format." Any ideas if what I'm trying is even possible? I know I could get a much clearer picture this way rather than using S-video (which works fine). PC in sig.
  2. kenco_uk
    28 Nov 2003
    Might sound silly but have you checked the refresh rate setting in Display settings?
  3. Pezboy
    12 Oct 2003
    yeah, I made sure to set it at 60Hz before shutting down and connecting to the TV.
