Electronics RGB LED control
Discussion in 'Modding' started by Vequalsir, 1 Sep 2005.
  1. Vequalsir
    Vequalsir What's a Dremel?
    25 Jun 2004
    I've been searching around for some sort of guide on using rgb leds. I'm not looking for anything too complex. I think it would be cool to have a group of them randomly fading from color to color.
  2. Glider
    Glider /dev/null
    2 Aug 2005
    Over at Metku they have a good guide... they use multiple leds, but you can just use multicolor and connect the legs accordingly
  3. DarkInferno
    DarkInferno Minimodder
    28 Nov 2004
    or over at bit-tech, they have a better guide and they use RGB LED's :hehe:
  4. Glider
    Glider /dev/null
    2 Aug 2005
    Now that you say it... :) But I tought that he would have searched that ;)
    BTW, the one at Metku only uses 2 leds (so it seems), so no RGB led :)
  5. Vito
    Vito What's a Dremel?
    19 Dec 2003
    If you are looking for just rgb fading leds, look at my answer in Rainbow LED . No components are needed. Only the led and, of course, the resistor. You can get these kind of leds in eBay.
  6. Vequalsir
    25 Jun 2004
    thanks dark inferno. I'm not sure why i didn't see it in the seach, but thanks for pointing it out.
  7. CollinstheClown
    CollinstheClown Hi
    30 Jul 2005
  8. One~Zero
    One~Zero What's a Dremel?
    9 Sep 2004
    What would be some suitable transistor replacements if I had an RGB with a 1 watt output? Could the same basic circuit still be used?
  9. g0th
    g0th What's a Dremel?
    12 Apr 2005
  10. digitalpbk
    digitalpbk What's a Dremel?
    12 Sep 2008
    rgb led project controlling some RGB leds via the USB using PIC microcontroller.
  11. Langer
    Langer Jesse Lang
    24 Jan 2004
    I've been playing with BlinkM rgb LEDs for PrometheusCU and I'm really impressed, you can use Arduino (they supply a simple arduino project to program them) to save colour sequences directly to the LED. The BlinkM's with then automatically cycle though the colours once you apply power.
    An Arduino control board will be needed.
    Here is the BlinkM homepage.
