RGB Server Case
Discussion in 'Project Logs' started by lamcdonald, 18 Mar 2004.
  1. lamcdonald
    lamcdonald New Member
    1 Mar 2004
    This is the case I decided not to use for Project F40. One of the original side panels is damaged, but the case I'm currently using for my server has side panels that fit this case. Unfortunately they aren't the right style for the F40 case.
    Anyway, I'm going to mod this one too. I started on it last night. Eventually it will be painted dark blue. The main feature of this case will be the lights and colours. I'm not going to put too many fiddly bits on it as it needs to be reliable :) (It's my proxy server; all my computers connect to the 'net through it)
    Unfortunately I'm kind of stuck... I need to put the system in another case to work on this one, but I don't have any more spares :/ I'll have to put either this one or the F40 case on hold until the other one is finished. I'll probably do this one first, as it won't take as long :) The system currently in this case is not the server; it's the system that will be put into the F40 case when it's done.
    The fans were originally green, as you can see:
    After a few minutes' work:
    [​IMG] [​IMG]
    Case before (a few weeks ago)
    [​IMG] [​IMG] [​IMG]
    Dremel time!
    [​IMG] [​IMG]
    Looking better... But still needs some work
    [​IMG] [​IMG]
    Much better! :D
    Next part: Power LED
    :D
    [​IMG] [​IMG]
    Night shot...
    Project Stats
    Date: Thu 18 Mar 2004
    Cost to date: $24.00
    Working Time: 2hrs
    Dremel disks used: 0.25
    Dremels killed: 0
    Parts discarded: 0
    Parts destroyed: 0
    Next: Not fully planned... heaps of things to do!
    Looking for: RGB Neon/CCFL
    Next update expected: Fri 19 Mar 2004
  2. JavaDog
    JavaDog New Member
    13 Mar 2004
    My vote is to continue the F40! :D That case is going to be bitchin'!
  3. Cereal
    Cereal New Member
    28 Feb 2004
    looks cool man, that case is just screaming.."mod me!" anyway.....have fun with it..
  4. lamcdonald
    1 Mar 2004
    Sorry everyone, I've been busy! Painting mice, etc... :naughty:
    I haven't done much, but I've got the lower front bezel basically finished :)
    The top part has been painted too, but I didn't get a pic. It's dark metallic grey. I'll keep slowly working on both current projects, hopefully I'll find an instrument panel for the F40 soon... :worried:
  5. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    that does look pretty sweet
  6. Incorpirate
    Incorpirate New Member
    2 Jan 2004
    looking good mate topstuff
  7. Cereal
    Cereal New Member
    28 Feb 2004
    yeaha...looks good..led fans really arent my style..but if you like um, its all you!!!
