Electronics Rheobus wiring questions
Discussion in 'Modding' started by NightBreed, 3 Mar 2002.
  1. NightBreed
    NightBreed What's a Dremel?
    8 Jan 2002
    After looking at the diagrams here {witch are very good} I still have a question.
    According to the one variable speed reobus you only recommend 10wats {80mm delta screamer ok} per channel
    well what Im looking at dooing is running this
    rheo 1 2x120mm delta 12v
    rheo 2 2x92mm delta 12v
    rheo 3 2x80mm sun <<< not sure on voltage
    is this doable?
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    You need to be more specific on the fan powers, but if its the 92mm Delta that draws 1.5A, you shouldn't put 2 in the same room, never mind rheostat. :eek:
  3. NightBreed
    8 Jan 2002
    Why do you say that?
    I already have the 2 120mm deltas 131cfm running why not ad the 2 92mm deltas for exhaust with my 2 80mms?
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I say that because Delta do at least six models of 12v 92mm case fan, ranging in current from 70mA to over an amp. I can't guess which you have.
    But two of the FFBs will burn out a 10W controller.
  5. NightBreed
    8 Jan 2002
    so your sayihng I should go with more then a 10 watt controller then. Wouldnt that make more sense?
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    If the fans on each channel add up to over 10watts, Yes.
  7. NightBreed
    8 Jan 2002
    do you happen to know whats the highest watt rheo they do sell
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
  9. NightBreed
    8 Jan 2002
    thanks bro
    Id buy ya a pint but Im in the states
