PSU rigging 2nd PSU to turn on and off (not the typical setup)
Discussion in 'Hardware' started by Springs, 24 Dec 2010.
  1. Springs
    Springs Boing boing
    29 Aug 2004
    Hi all,
    I've got a mini itx board which runs from a 12v socket on the back of the botherboard and doesn't use the typical atx PSU's.
    The problem i have is that it can't provide the power to user 5 hard drives. The most it can do at a time is 3.
    What i'm wanting to do is use the original case PSU to power the hard drives for the time being but need to know if its possible to make the PSU switch on and off via the green wire when the motherboard does.
  2. hitman012
    hitman012 Minimodder
    6 May 2005
    You could use the output of the ITX PSU to drive a relay which would connect the green wire to ground.
  3. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    There's an off-hand (read: very unlikely) chance that your motherboard offers a staggered startup, so that your hard drives don't all spin up at the same time. Might save you the trouble of having to rig up a second PSU.
  4. Publ!c Enemy
    Publ!c Enemy or Richard for short
    4 Jul 2010
    Like hitman said, connect the output to the green wire on the PSU, to start it up.
  5. Remeniz
    Remeniz Muted!
    18 Dec 2010
    It's possible and you don't need a relay. I build a loom, using an ATX extension lead, some green and black cable and an ATX male plug, that you connect to the output of a PSU, connect the other end to the motherboard and I wired a 3rd ATX connector to the black and green leads. This 3rd connector connected to my 2nd PSU.
    Just use the green and any black lead to power the second PSU.
  6. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    if im hearing remeniz right, and what i would do, is connect the green wire from the 2 PSUs together and ground the PSUs to each other. when the motherboard grounds the green wire, it will ground both PSUs and they will both turn on.
  7. JaredC01
    JaredC01 Hardware Nut
    24 Nov 2002
    hitman had it right...
    For the rest of you:
    He has a motherboard that uses a brick, similar to a laptop. There is no green wire, and theres no easy way to access one.
    Pick yourself up a cheap NO (normally open) 12v relay from Radio Shack, hook the input coil leads up to 12v and ground from a molex connector on the motherboard, then hook the green wire from the case psu up to one side of the output, and a ground from the case psu up to the other side. Once the system powers up it will close the relay, and complete the case psu's turn-on circuit.
    If you need a diagram, I can draw something up in paint when I get home.
  8. Wicked_Sludge
    15 Aug 2010
    ahh, in that case:
  9. Deders
    Deders Modder
    14 Nov 2010
    be very careful that that the power from each PSU doesn't meet at any point as the difference in power fluctuations could damage your hardware
  10. Remeniz
    Remeniz Muted!
    18 Dec 2010
    You mean like this?
    OP:
    What mini itx board do you have?
  11. JaredC01
    24 Nov 2002
    Not a bad diagram, but in this case the ground for the green wire needs to come from the case psu, or both grounds for each psu need to be combine so there's a common ground.
  12. Wicked_Sludge
    15 Aug 2010
    i think combining grounds would be easiest for wiring, but either way would work.
