Small Form Factor Right angled AGP converter/riser
Discussion in 'Hardware' started by madmuppet, 17 Dec 2003.
  1. madmuppet
    madmuppet What's a Dremel?
    13 May 2003
    Does anyone know where i can get a right angled AGP riser, i found loads of sites doing the PCI card one but none for an AGP port.
  2. sco0by
    sco0by Mmm pie.
    12 Dec 2001
  3. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    I have a 2U AGP riser I don't need. If you want it just send me a PM
  4. madmuppet
    13 May 2003
    thanks for the replies - i'm after the smallest one possible so i think the 2U one might be a bit big.
  5. Golden-1
    Golden-1 Minimodder
    23 Aug 2003
  6. Poison The Well
    Poison The Well What's a Dremel?
    19 Dec 2002
    What exactly do right angle AGP risers do? Just swith the orientation of the AGP card?
  7. Wndrbread
    Wndrbread What's a Dremel?
    13 Dec 2003
    Right angled agp risers raise the card a bit and make the card lay parallel to the motherboard
  8. Poison The Well
    19 Dec 2002
    So it would allow you to put a graphics card with an oversize heatsink / fan into a SFF case? Gothca.
  9. njin
    njin What's a Dremel?
    29 Dec 2003
    Hmm, don´t you need a LEFT angled riser card to let the agp card point to the cpu? Those I´ve seen make the card lay parallel to the PCI slots, so they won´t fit in a SFF case, do they?
  10. Wndrbread
    13 Dec 2003
    Dunno i dont have a SFF iv only seen them on Servers and they lay them over the PCI slots so they can make 1u units fit
  11. njin
    29 Dec 2003
    Right, but most of the motherboards in SFF cases, like the FN45 in my Shuttle SN45G, don´t have more than one ore two pci slots. Standard atx mobos got five or more left-handed to the agp slot. Consequently I got to use my Dremel to be able to use such a riser card! :D So I would need one that makes my graphic card point to the other direction to make it lay over the cpu...
    Know what I mean?
  12. Pistol
    Pistol Guest
    If you have a full tower ATX mobo riser, then use this riser. Otherwise it would be useless in a SFF pc
  13. 1398342003
    1398342003 Ubermodder
    2 Sep 2002
  14. counterclockwise
    counterclockwise What's a Dremel?
    17 May 2003
    they are really hard to fornd... captain slug, i'd be interested in your riser, can i have some dimensions please?
