Rigid tubing, who's using it and what brands?
Discussion in 'Watercooling' started by dynamis_dk, 17 Apr 2014.
  1. Hukkel
    Hukkel James' minion
    20 Dec 2012
    ALmost all brands have the fittings now. I have used EKWB, Bitspower and Diamond Cooling and all were equal in how well they worked.
    Tubing can be obtained from anywhere. I have used E22 a lot, but also from ModWithMe when it was still active and it is all pretty much the same.
    It is a matter of looks which ones you want to use.
  2. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    THAT!
    That right there is what I want to do!
    Though maybe in polished copper.
  3. MarkVarley
    MarkVarley Member
    12 Sep 2014
    E22 in EK fittings, latest build will be at plumbing stage soon.
    Sent from my GT-I9505 using Tapatalk
  4. Colaboy
    Colaboy New Member
    5 Aug 2014
    I'm using Barrow fittings, can be quite tricky and wasteful trying to bend them.[​IMG]
  5. Bradley8988
    Bradley8988 New Member
    16 Jun 2008
    What coolant are you using colaboy?
  6. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    My copper tubing is 15 mm OD, would a standard 16/12 fitting be usable for this purpose?
  7. Colaboy
    Colaboy New Member
    5 Aug 2014
    i'm using Mayhems Pastel White with UV red concentrate and red dye mixture
  8. Nexxo
    Nexxo Queue Jumper
    23 Oct 2001
    I'm using 12mm OD, 10mm ID brass tubing with BitsPower True Brass C47 Enhanced fittings. They have a ridiculously string grip --that tubing won't pop out!
  9. colinmcr
    colinmcr New Member
    1 Jul 2014
    I'd love to see proper minature flanged pipe, just for the effect in some sorta steampunk build
