Scratch Build – In Progress Ringo's la ultima [11-03-07 update]
Discussion in 'Project Logs' started by ringo, 26 Apr 2009.
  1. The boy 4rm oz
    10 Apr 2008
    I am truly amazed. Beautiful work.
  2. Ashaman
    Ashaman M'hael
    17 Mar 2008
    Whoow!
    This is some serious plexi skills! And those reservoirs looks amazing!
    Looking farward to follow this thred!
  3. ringo
    ringo What's a Dremel?
    14 Jun 2008
    Thanks a lot for the great response.
    Today I milled the acrylic tube, that means that I cut 13mm off. I approximated the time to do it on 2h. I was very suprice suprised that I only ned 1.25h to do this. The next step will be the grinding of the cutted surface.
    Here are some pictures, who I made.
    The last figure indicates the cracked area.
  4. Macros_the_Black
    Macros_the_Black Yup.. I'm a f-ing reptile
    7 Jul 2007
    Pure awesomeness!!! I'm getting definite "Tribal-vibes"! 8)¨
    Keep up the excellent work!!!
  5. kenco_uk
    28 Nov 2003
    You know, I was looking through and thinking, "Is that thing going to spin in the water?"
    Then I thought, "It looks like it's going to spin, cool"
    Then I watched the video and now think, "Holy Crap, that's amazing!"
    Props to you, that's crazy!
  6. ringo
    14 Jun 2008
    Thanks, yes both rotores should spin in the water, if it is done, it schould rotate in oposite directions. With a single rotor works fine while the testings. The main problem is do get both bearing exactly upon each other. If both are aligned the rotor works very well, it will work with a little pump. The pump pumped round about 300l/h, the pressure head is 0.6m. The aligenment of the bearing will be a problem, but I think i can managed it.
    The first idea was. The water should flows throug the acrylic wings. I can't realise that, because I couldn't drill a 1.5mm hole in a 3mm acrylic. I have try it, but the only resoult was, broken drills. So I changed the concept to tubed outlets. And now I think that was the right decision.
  7. ringo
    14 Jun 2008
    Hello together,
    the first part of the update is the grinding of the acrylic. After the cutting i milled the surface, I milled 1mm off, but that was a bit to much risk. I decided to grind the rest. After the milling I had one crack inside the acrylic, that crack was the old one from the bonding. The crack was 1mm deep. First I used a 180grit Sandpaper. Then i changed the sandpaper to a 400grit. The last one, who I used was a 2000grit. I allways grinding wet, because the results of the grinding are much better.
    Now I will show you some pictures.
    Some Pictures of the used sandpaper.
    Next a figure which illustrates the post modern grinding machine:D
    The last one shows the grinded acrylic.
    The other part is the modification of a air relief valve.
    The problem was that i don't have a 1/2" thread drill. I only have a 1/4" thread drill :wallbash:
    My Dad had the idea to bonding a 1/4" fitting end on the turned end of the air relief vavle. So I had to turned the 1/2" threaded end on diameter of 7,5mm, that was the inside diameter of the fitting. After I turned the 1/2" end I turned to notches in the end surface. The inner notch is for the 1/4" fitting
    I decided to use a sealing, so I have to make a second notch. For this notch I used a selfmade truning chisel. I rounded the egdes. I have made this chisel for the sealings in the friction bearings.
    After the turning I have to bonding the two parts together.
    The finished part air relief vavle. Only the top part of the valve is missing.
    I hope you will understand my english explanations.
  8. The boy 4rm oz
    10 Apr 2008
    You made your own release valve? AWESOME!!!
  9. ringo
    14 Jun 2008
    I think it's better to say. I mod one. Here is a picture of the original
    This valve has a 1/2" thread, but I only have a 1/4" thread drill.
  10. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    exactly what i was thinking
  11. ringo
    14 Jun 2008
    Hello together,
    today I startet the drilling work on the acrylic tube. I have to drill 3.7mm holes in 5mm thick edge of the acrylic.
    I used the mill to do this job. First i mark the positions with a 3.3mm drill, which I use to drill the mounting holes in the bottom and top plate.
    After that I changed the drill, I have to use a 3.7mm drill for the brass mounting inserts.
    There wasn't much space for mistakes.
    The next two pictures showing the holes on one side. The depth of the holes ist 4mm.
    Tomorrow I will drill the second side of the acrylic tube.
  12. The boy 4rm oz
    10 Apr 2008
    Really nice drilling, so precise.
  13. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Impressive work, I would have broken the acrylic tube by now.
  14. aevitas
    aevitas What's a Dremel?
    6 Mar 2005
    Haha I hear ya, it really looks scarily close those drilled holes. But I guess if you take it slow and just have patience, you'll get what you want.
    Keep it up, it really is starting to look good already.
  15. DonT-FeaR
    23 Jul 2008
    wow... thats precise.. great work mate
  16. ringo
    14 Jun 2008
    Thanks for the good feedback.
    Today I start a new part. It is a mounting part for the release valve. I wont cut a 1/4" thread in the acrylic, so I decided to make a mounting. First of all I sketch the part in cad, then I make a quick drawing, with the most important measurement.
    Then I start turning. I used a round aluminium with a diameter of 55mm.
    Then I drill the hole for the thread.
    Then i turned the inside and outside shape.
    In the next picture you can see one of my favorite chisels ( it's a self grinded chisel)
    Before off cutting
    The off cutted part, tomorrow I will finish this part. I have to drill some holes and I had to trun a noutch for a sealing on the backside.
    The other part, who I start to build yersterday was a mounting clamp for my 8x8 mm chisels. The old clamp, which is made out of aluminium is at the end of life, so I have to make a new one. The problem on the old one are the threads vor the clamping screws.
    The next two figures shows the milling and the end milled part.
  17. The boy 4rm oz
    10 Apr 2008
    Beautiful machining.
  18. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    This is looking great! I love some heavy duty plexiglas fabrication.... and some seriously good machining!
    great job, can't wait to see it develop.
    subbed
    I too would have probably broken it many times and stomped it to pieces by now! :D
  19. Infiniti
    Infiniti i modded the wheel!
    3 May 2009
    :jawdrop::jawdrop::jawdrop: holy cr*p this work is amazing... complete custom fabrication rocks!! can we have your address to rob the finished product :D
  20. bagman
    bagman Minimodder
    18 Apr 2009
    :jawdrop::thumb::thumb::rock:wow boy are you good
