Other RIP something...
Discussion in 'Hardware' started by ninjaplease, 28 Sep 2012.
  1. ninjaplease
    ninjaplease I don't know what I'm doing
    11 Jan 2012
    Sup guys, been a while..
    My problem today is that whilst watching some youtubes, my computer cut out, and now won't turn back on. There were no popping noises, no burning smell, no obvious damaged components inside..
    Any suggestions on what to do? Is there an easy way to test my PSU?
    Cheers :thumb:
  2. mrbungle
    20 Sep 2004
    Check fuse first.
    Then ideally crosscheck everything else with another computer. Id prob start with the psu if it is lifeless.
    ninjaplease likes this.
  3. Ripitup121
    Ripitup121 MMMMMMm watercooling....
    18 Aug 2010
    Yep plug fuse and check switch on the fuseboard in your house did'nt trip first then you can check your PSU by hotwiring green to black on the main 24pin atx with a paperclip or a bit of wire (dont worry you wont shock yourself) and see if there is any life in it.
  4. ninjaplease
    11 Jan 2012
    Mmkay so I shorted the green to black and the fan started spinning, does that mean something more expensive has broken then?
  5. zulu9812
    zulu9812 New Member
    21 Oct 2010
    Would a CMOS battery reset help here?
  6. ninjaplease
    11 Jan 2012
    Tried it, nothing happened. Guess it's time for a new board, shame this one only lasted about 3 months.
  7. Speed
    Speed I'm all you need!
    13 May 2004
    Disconnect everything that isn't required to boot, optical drives, hard drives, graphics card (assuming this is the system in the sig, connect the monitor to the motherboards I/O and pull the graphics card), also go to a single stick of ram and see if it posts.
  8. ninjaplease
    11 Jan 2012
    Will do. I'm so cursed with computer problems, I've never gone more than 6 months without some catastrophe, is this normal? It's not like I'm not buying legit components.
  9. Somer_Himpson
    Somer_Himpson New Member
    22 Jan 2010
    Warranty?
  10. law99
    law99 Custom User Title
    24 Sep 2009
    WARRANTY
    EDIT: Seriously. Check all components in another pc that you can to try find the warranty issue, if it is one.
  11. ninjaplease
    11 Jan 2012
    Just thought I'd let y'all know it was the GPU that was toast, thanks for all the helps. Reps all round.
  12. Chicken76
    Chicken76 Active Member
    10 Nov 2009
    What PSU do you have? I might be faulty and damaging components in time.
  13. ninjaplease
    11 Jan 2012
    After much confusion and rage, it turns out having my speakers plugged in was the issue... All components are fine, just something must be shorted out in my amplifier.
  14. zulu9812
    zulu9812 New Member
    21 Oct 2010
    Interesting - the amplifier is an external unit? I wouldn't have thought that that would affect the boot sequence.
  15. lp rob1
    lp rob1 Well-Known Member
    14 Jun 2010
    Ah, the old amplifier feedback problem. Had a case like this at school. Big meaty amplifier shorted back up the line, completely frying the motherboard.
  16. Somer_Himpson
    22 Jan 2010
    Troubleshooting everything is a given.
    If the board is borked and only 3 months old then it should be under warranty was my point.
    No need for the attitude!
  17. ninjaplease
    11 Jan 2012
    This seems to be the case. I tried plugging the jack into my monitor and using an hdmi cable to send the audio through, but after a couple of hours it died again and what I did to fix it last time no longer works. Any idea what I can do about it? This is beyond frustrating :/
  18. law99
    24 Sep 2009
    I remember installing windows on one pc. Once all was finished it wouldn't boot. I couldn't for the life of me figure why because I "knew" the cd-rom drive worked because I just finished installing windows with it.
    Long story short: Turns out, it was the cd-rom drive.
