Windows Ripping DVD
Discussion in 'Software' started by Millusdk, 24 Apr 2010.
  1. Millusdk
    Millusdk What's a Dremel?
    27 Jan 2008
    Hey Everyone,
    I am trying to rip the DVD's from the Stargate: SG1 boxed set, so that I can watch them without needing the disks. To rip them i am using Leawo DVD ripper, but it cannot read the disk for some reason, keeps saying that it is an invalid DVD video disk directory.
    Has anyone else had this problem with a DVD, and how did you work around it?
    Btw, the disks play fine in VLC
  2. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    Chances are it has protected sectors.
    Things you'll need:
    - DVD Decrypter
    - DVD Shrink (make sure DVD shrink doesn't parse the files)
    - AutoGK
    - RipIt4Me
    Prefered workflow:
    RipIt4Me > DVD Decrypter > DVD Shrink > AutoGK
    I hope I'm not in violation of forum rules. If I am, feel free to delete my post.
  3. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    MakeMKV all the way.
    Everything else is just too much hassle, couldn't be bothered to rip my 150+ DVD collection until I found about MakeMKV. A bloody brilliant program. So far only Casino Royale in my collection has been too tough for it, so I left it alone.
    RinSewand likes this.
  4. MiT
    MiT Don't feed me after midnight!! nom
    18 May 2005
    am sure doom9.org, guides sections can help you out.
    Millusdk likes this.
  5. heir flick
    heir flick Minimodder
    2 Feb 2007
    dvdfab free will do it
  6. Millusdk
    27 Jan 2008
    MakeMKV did the trick, thanks a lot :)
  7. Millusdk
    27 Jan 2008
    One more thing. MakeMKV turns the DVD's into mkv files that are pretty big 1g+ for a 40 min video, does anyone know a program that can convert from mkv to avi?
    NVM found one
  8. wormy
    wormy Minimodder
    16 Oct 2009
    Which one? You tease!
  9. Millusdk
    27 Jan 2008
    Sorry, its name is Any Video Converter Freeware and it can be found here: http://www.any-video-converter.com/products/for_video_free/
    Haven't tested the resulting files yet, it was running on my desktop machine when i left home this morning, so hopefully it is done when i get home, will post update with the results :)
  10. Krikkit
    21 Jan 2003
    Why use RipIt4Me and DVD Shrink?
    DVD Decrypter -> AutoGK is all you need.
  11. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    I use DVD Fab and then Handbrake to convert the .vob files to MP4
  12. wormy
    wormy Minimodder
    16 Oct 2009
    I had better start trying some of these to see what I like.
    I like frogs so am tempted to try krikkit's line but I like monkeys too, so Votick has a vote. Hmmm...ah, Auto GK seems to do DivX so I think I'll start with that (for dvd player compatibility).
  13. padrejones2001
    17 Jun 2004
    I only use that workflow when the DVD has protected sectors (once in a blue moon, but it does happen), otherwise, I go directly from DVD Decrypter to AutoGK.
  14. Millusdk
    27 Jan 2008
    MakeMKV and Any Video Converter Freeware does the trick, so thanks for the help everyone :)
    Now i just need to rip all the disks :)
  15. oposky2006
    oposky2006 What's a Dremel?
    23 Oct 2009
    Is your dvd encrypted one? Your dvd ripper may not support commercial dvds. U need a dvd ripper which can decrypt and then rip your dvd off from disc. Im using Pavtube Blu-ray Ripper which can rip any protected DVDs and copy to my harddrive.
    Hope good luck with u too.:clap:
  16. Millusdk
    27 Jan 2008
    I think they are encrypted, but MakeMKV is able to decrypt and copy the files to the harddrive, so I am a happy camper :D
  17. Millusdk
    27 Jan 2008
    Turns out the conversion from .mkv don't work so well, once it has been converted, the image don't scale up like it does with the .mkv files.
    Does anyone know a converter where this problem does not exist, or is it because I have not set the right config options?
  18. gavomatic57
    gavomatic57 Minimodder
    23 Apr 2009
    DVD Shrink still works well for me. I then use Badaboom to use the GPU to make mp4's for my iphone or PSP.
  19. woods
    woods What's a Dremel?
    27 Apr 2010
    Dvdfab has always worked well for me as long as you update it every now an then
