Displays Ripples and waves when moving/adjusting monitor
Discussion in 'Hardware' started by Sintek, 30 Mar 2011.
  1. Sintek
    Sintek What's a Dremel?
    29 Mar 2011
    Picked up an Acer LED LCD the other day. I didn't know it was an extra slim model, but I figured a little extra space doesn't hurt so I decided to keep it. However, when I either move it or adjust the tilt it send waves across the entire display as though I punched it in the screen. Could this to lead to damage to pixels or eventual warping of the display? It really does feel delicate and I can't find any safe place on the bezel to use.
  2. Digerati
    Digerati Minimodder
    19 Feb 2011
    It is a common occurrence. Putting physical pressures on an LCD screen distorts the physical dimensions of the liquid crystals. As long as the distortion goes away and the monitor behaves normally when you don't put pressures on the screen, you are okay.
  3. azazel1024
    azazel1024 What's a Dremel?
    3 Jun 2010
    If you like adjusting your monitor several times a day, I'd consider returning it and getting something with a bit stronger chasis/bezel. It you only have to adjust it occasionally, I wouldn't worry about it like Digerati mentioned. It is semi-normal, though most monitors I have seen you have to press on the bezel pretty hard to really try to torque it to do it over the whole screen.
  4. Deders
    Deders Modder
    14 Nov 2010
    Even calulators do it
  5. docodine
    docodine killed a guy once
    10 Feb 2007
    You're giving up a lot of structural integrity with those extra thin models, especially with a cheap brand like Acer.
  6. Digerati
    Digerati Minimodder
    19 Feb 2011
    Even with higher end models, the desire for thin this and thin that often means less rigidity. Even a sheet of steel will flex and warp with fairly little effort. The different is, the steel is not electrically charged and lit up to see the effects.
