Modding rivoted on?
Discussion in 'Modding' started by ChuckleMuffins, 24 Feb 2002.
  1. ChuckleMuffins
    ChuckleMuffins What's a Dremel?
    18 Feb 2002
    I have a quandry.
    Gotta paint me case.
    All sides are removable......except the top.
    It is (and i think this is the right word) "rivoted on" which means that instead of screws holding it in place it has like unscrewable screws, which means i can't take it off with the normal screw driver.
    I really don't want to paint this top piece while its on my case.
    Is there any way to take out a rivot? or should i just paint it while its on my case?
    i feel really stupid for asking this but i want a professional opinion because i am a moron.
    Thanks,
    Chuckles
  2. brianpodskalny
    brianpodskalny ladies night!
    3 Nov 2001
    get a drill, and drill the rivets out.
    then get some screws and put those in instead. or get some pop rivets if you really want the rivets back.
  3. UnLoadeD
    UnLoadeD What's a Dremel?
    2 Jan 2002
    You can get the rivots off with a drill or a file. Either way you just gotta get rid of the "head" on the outside that you can see, and then just push it thru. You'll need a pop-rivot gun to put it back on when you are done tho. Screws might work, if you can find some with really flat heads. Make sure everything is out of your case before you start drilling or filing. You dont want any metal shavings getting in the wrong place.
  4. Geek
    Geek What's a Dremel?
    21 Nov 2001
    Gotta agree with these guys. Sometimes it's kinda tough to get them - my car had a similar way of mounting the speakers, and those guys were little whores to get out. I'd recommend a corded drill, if you've got one or a way to get your hands on one.
    Gordon
  5. Lag Messiah
    Lag Messiah What's a Dremel?
    7 Feb 2002
    To get the top panel off my LianLi when I was putting in my blowhole I just used a drill bit on the trusty Dremel :D
    Worked like a charm
  6. tk421
    tk421 Idiot.
    15 Jan 2002
    usually those rivets are aluminum, a new (sharp!) dril bit should chew right thru em.
  7. bajastx
    bajastx What's a Dremel?
    22 Jan 2002
    Yes a 1/4 in. drill bit (8mm) will work on most case rivets.
    ... btw it's "riveted".
  8. LoopyJuice
    LoopyJuice Astronomical
    24 Jun 2001
    omg lian-li are mean ppls! pay £155 for me new pc 65 and theydon't let you take the top off! ah well i don't need to anyway hehe :rolleyes:
