Networks RJ45 face plate without punch down
Discussion in 'Hardware' started by MarkW7, 14 Nov 2015.
  1. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Does anybody know if there is a RJ45 single face plate where you can put an RJ45 cable in to the back of it that is already crimped instead of punching down the 8 cables?
    Basically I have a cable that goes through walls and cannot be replaced but the 8 cables inside are really low quality, they're too thin and won't punch down properly.
    ATM I've crimped it and use a coupler to get by until I can see if such a product exists!
    These are the only types I can find.
  2. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
    you could punch down a good rj45 cable a couple of inchs long cable,, then use a female female rj45 extender to put your cable into.
  3. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Yeah, that was my plan B. Single back box is tight but think it would fit.
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    phuzz likes this.
  5. phuzz
    phuzz This is a title
    28 May 2004
  6. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Thank you! Have you ever used on Atomic? Do you know what size back box is needed it looks quite deep.
  7. Atomic
    Atomic Gerwaff
    6 May 2002
    Not sure how deep they are, only seen them in floor boxes with floating floors. I'd imagine only a few mm bigger than the two jacks that go into them.
    Contact cablemonkey and ask, they are nice chaps and will likely measure one for you :)
  8. ToneEQ
    ToneEQ What's a Dremel?
    19 Nov 2015
    I learned something new today. I've just finished wiring everywhere upstairs at home and these will save me a lot of time when I fit the faceplates!
  9. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    tenda make combined socket wifi access point the tenda w312a it has a socket on the back to connect normal rj45 cable ends
