Electronics RJ45 socket
Discussion in 'Modding' started by Kipman725, 27 Mar 2007.
  1. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    quick question, anyone know where to buy one from that is pretty easy to solder wires onto?
    Am I best to canibilise a wall socket?
  2. Zacrobmer
    Zacrobmer What's a Dremel?
    13 Feb 2007
    Never used a solder version, but the push on style are easy enough to use. The wires are laid in a channel and then pressed in with a tool (can't remember the actual name). You can also find tool-less version that use a cap to press the wires.
  3. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Cannibalise a wall socket, just rip the connecters off and there are solder points underneath.
  4. ch424
    ch424 Design Warrior
    26 May 2004
    Do you have all the right magnetics? If not, try and get a MagJack one, apparently they're pretty good. Alternatively just look here for a normal connector.
    Though if it's not PCB mounting and you don't need the magnetics, a wall socket might be cheapest.
  5. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    I kinda doubt he's building his own network adapter.
    Unless you are, you don't want one with integrated transformers ("Magnetics").
  6. ch424
    26 May 2004
    Just checking... I needed one when I made mine...
