Scratch Build – Complete ⭐ ROBO RONE
Discussion in 'Project Logs' started by pcroombrasil, 19 Feb 2019.
  1. pcroombrasil
    pcroombrasil Minimodder
    27 Nov 2017
    Projeto ROBO RONE.
    perdoe o ingles mas é que como nao sei escrever usei o traduto.
    Project ROBO RONE. (ostensible rounds of special nature)
    Forgive the English but it is that as I do not know how to write I used the translator.
  2. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Just opened one random pic and was totally blown away ! i mean totally ! i love this stuff
    please fix up the pics so they show.... i want every one to see this :rock::rock::rock:
  3. kim
    kim hardware addict
    10 Jan 2016
    I can see only 10% of the pics, and none of the vids, what a pity :oldconfused:
  4. yuusou
    yuusou Multimodder
    5 Nov 2006
    @pcroombrasil separa o teu post em vários, separa o projecto por fases. Para as fotos, usa a tag [IMG. É o símbolo que parece um quadro com montanhas no editor.
  5. pcroombrasil
    27 Nov 2017
    Projeto ROBO RONE.
    especificacoes
    placa mae asrock taichi x399
    processador threadripper 1920x
    memorias team group tforce 8x8gb
    placa de video gtx 1080ti galax hof
    font 750w evga
    ssd 240gb teamgroup 2x
    sistem custom liquido
    radiador 360mm alphacool
    radiador 240mm thermaltake
    2x pump d5
    reservoir ek and thermaltake.
    5 fans thermaltake riing plus
    mangueira e fittings de varias marcas.
    specifications
    mother board asrock taichi x399
    1920x threadripper processor
    team group tforce 8x8gb memories
    gtx 1080i video card galax hof
    evga 750w font
    custom liquid system
    radiator 360mm alphacool
    radiator 240mm thermaltake
    2x pump d5
    hose and fittings of various brands.
    Sou Policial Militar no brasil e trabalhei nas operacoes especiais do paraná/brasil chamada de RONE. Para esse projeto pensei em fazer um robo que lembrasse o ED-209 do filme ROBOCOP.
    Para isso utilizei o programa sketchup para projetar o desenho.
    I am a Military Police Officer in Brazil and I worked in the special operations of the paraná / brazil called RONE. For this project I thought of doing a robbery that would resemble the ED-209 from the movie ROBOCOP.
    For this I used the sketchup program to design the drawing. 1.png 5.png 1.png 5.png 6.png 7.png 8.jpg 8.png
  6. pcroombrasil
    27 Nov 2017
    Resolvi trabalhar com acrilico para suportar o peso da estrutura, e para dar forma utilizei PVC expandido. Depois de terminar de realizar o projeto, comprei uma cnc router e utilizei o Skechucam para realizar os cortes. fiz os recortes e depois dava acabamento com lixa e tupia. depois colei as partes com superbonde e reforcei a estrutura com cola plastica.
    I decided to work with acrylic to support the weight of the structure, and to shape I used expanded PVC. After completing the project, I bought a cnc router and used the Skechucam to perform the cuts. I made the cutouts and then finished with sandpaper and tupia. then glued the parts with superbonde and reinforced the structure with plastic glue.
  7. pcroombrasil
    27 Nov 2017
  8. pcroombrasil
    27 Nov 2017
    Foi montado sistema motorizado com motor de passo de 100 kg controlado por arduino.
    outros motores foram instalados para as armas e pistoes.
    It was assembled motorized system with stepper motor of 100 kg controlled by arduino.
  9. pcroombrasil
    27 Nov 2017
  10. pcroombrasil
    27 Nov 2017
  11. pcroombrasil
    27 Nov 2017
    Projetei pisotes com bordas de leds enderecaveis
    I projected piles with edges of light-emitting diodes
  12. pcroombrasil
    27 Nov 2017
  13. pcroombrasil
    27 Nov 2017
    Hardwares
  14. pcroombrasil
    27 Nov 2017
    Tive de criar um block processador pois não tinha no brasil.
    I had to create a block processor because I did not have it in Brazil.
  15. pcroombrasil
    27 Nov 2017
  16. pcroombrasil
    27 Nov 2017
    comecei a pintar as pecas e montar. usei a cor aluminio para parecer metal e preto para a parte principal.
    I began to paint the parts and assemble. I used the color aluminum to look like metal and black for the main part.
  17. pcroombrasil
    27 Nov 2017
    e por fim a montagem e teste finais .
    and finally final assembly and testing.
  18. pcroombrasil
    27 Nov 2017
  19. pcroombrasil
    27 Nov 2017
  20. pcroombrasil
    27 Nov 2017
