Scratch Build – Complete Robocop Casemod - ED-209 by RandomDesign
Discussion in 'Project Logs' started by random2k4, 1 Sep 2023.
  1. random2k4
    random2k4 Multimodder
    11 Aug 2015
    After all parts were post processed, I started with the priming and paint job.
    I went for a slightly darker grey tone then in the original, just to make the metal detail pop more at the end.
    Some parts also got a small darker details.
    After everything was primed, the weathering with black and brown colors followed.
    Everything was still a little too bright. So, I went over each part with a dark black/brown wash.
    This also helped ti really tie together the weathering affects applied before.
  2. Monkey Puzzle
    Monkey Puzzle Minimodder
    18 Feb 2009
    Looks like a £1m Games Workshop box set!
    That brown wash looks great :thumb:
  3. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
    What a beauty you create, bro! God bless you with good health and many more years of life. :dremel:
    random2k4 likes this.
  4. random2k4
    11 Aug 2015
    Haha thanks mate. Still young, there is way more to come!
    While the paint and clear coat was drying, I finished casting the last detail pieces.
    All metal parts were then hit with a layer of brown and black metal wax for a suttle weathering effect.
    Quite some parts.
    Next, I sanded down some black screws and glued them in to the some holes of the detail parts
    to create an even more mechanical look.
  5. random2k4
    11 Aug 2015
    Finally, it was time to bring everything together.
    Started with the back of the leg. All parts are glued and further stabalized
    with some metal rods.
    For the rail parts, I didnt used any glue, but simply put them into place.
    After the first parts were put together, it showed that it is quite a complex build.
    Next, I started combining all the pieces for the weapon arms.
  6. Cheapskate
    13 May 2007
    :worried: V2 is going to be some Boston Dynamics- tier thingamagiggy, right?
  7. arduum
    arduum Minimodder
    10 Mar 2015
    I hope you don't have a "glitch" :grin::rock:
  8. Cheapskate
    13 May 2007
    "Update to windows 11! You have 20 seconds to comply!"
    random2k4 and arduum like this.
  9. random2k4
    11 Aug 2015
    Next, I needed the elbow part that holds the weapon arm.
    I glued the 3 resin cast parts together and stabilized it with an aluminum rod
    inserted in the middle.
    The weapon at the front end was simply resin printed and colored black.
    For a little metalic effect it was dry brushed with some silver paint.
    And the workbench was full again.
    Then the assembly of the legs followed.
    To hold everything, the core was made out of a 2x2 cm aluminum profile.
    Every part was slided on the profile one by one.
    Then I made the first real test assembly on a ply wood board.
    Then I built in the hardware. Unfortunately, I dont have pictures of that, but its not really spectacular.
    Next, there will be fome final images.
  10. Cheapskate
    13 May 2007
    It's not as intimidating at that scale. Dare I say... it's cute?
    Check on the legality of adding 4 airsoft guns to it before doing V2, though. :lol:
  11. random2k4
    11 Aug 2015
    3 Airsofts and a Nerf Blaster for the rockets.
  12. censored_Prometheus_
    26 Mar 2019
    That reminds me of something...
    Vault-Tec, IanW and random2k4 like this.
  13. arduum
    arduum Minimodder
    10 Mar 2015
  14. random2k4
    11 Aug 2015
    And some final images + making-of
  15. Idioteque
    Idioteque Telephasic Mongoose
    21 Aug 2004
    Now that's an Enforcement Droid! Very impressive work.
  16. arduum
    arduum Minimodder
    10 Mar 2015
    :jawdrop::jawdrop::jawdrop:
    I propose that we hire Mr. random2k4
