News Roccat launches Kone Pure Optical mouse
Discussion in 'Article Discussion' started by Gareth Halfacree, 26 Jul 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    I'd love to know why they think lasers help.
  3. Gareth Halfacree
    4 Dec 2007
    Eh? The Roccat Kone Pure Optical doesn't use lasers; the entire point is that it uses an LED-based optical sensor instead. The Roccat Kone Pure uses a laser, as the article makes abundantly clear.
    As for why lasers help (or hinder): a laser-based light source on an optical sensor allows for much finer-grained accuracy. Just look at the figures: the Roccat Kone Pure Optical, with its LED-based light source, tops out at 4,000dpi; the Roccat Kone Pure, which uses a laser-based light source, hits 8,200dpi. That's more than double the resolution.
    Some don't like the 'feel' of a laser-based sensor, however, and would prefer the old-style LED light source. It's for these that Roccat has built the Kone Pure Optical.
  4. Phil Rhodes
    27 Jul 2006
    Sure, absolutely, the question was more "why does it ever make a difference". I appreciate they have larger resolution figures, but it isn't clear to me why that's necessarily associated with the character of the illumination. Modern optical mice frequently use something like a 4x4 or 8x8 pixel "camera" looking down at the surface on which the mouse is running. I suppose you could take the position that the finer light source of a diode laser casts sharper shadows from the details on the desktop but the resolution of the thing is ordinarily more down to the detector than the emitter.
    After all, a diode laser pretty much is an LED, just one about the size of a bacterium.
  5. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    The reason the DPI is greater with LASER mice is because of the rectilinear quality of a LASER beam compared to the highly divergent nature of all other types of light sources, including non LASER LEDs.
  6. Xir
    Xir Modder
    26 Apr 2006
    Back to the roots.
    Next year, a direct-kinetic-driven mouse for those hardcore gamers out there...you know, with a rubber ball in it ;-)
  7. lankymorley
    lankymorley What's a Dremel?
    6 Aug 2012
    As a low sensitivity gamer, I've never been satisfied with the tracking of a mouse with a laser sensor. Optical all the way!
  8. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
    Voice command is the way to go:
    "Left a bit, right a bit - Fire!".
