Scratch Build – Complete "ROG Carbine" DCMM 1.place
Discussion in 'Project Logs' started by ronny78, 4 Sep 2017.
  1. ronny78
    ronny78 Member
    13 Aug 2015
    Welcome to my next project
    "ROG Carbine"
    The carbine is based on the "verc carbine" concept of Aaron de Leon,
    a 3D designer (hard surface modeling) already involved in the development of several games such as Star Citizen and Section 8.
    When I saw this concept, I realized immediately that I must build it.
    I immediately recognized a Pc in the carabiner, so followed also various drawings until I realized where the whole leads.
    Many pictures do not exist of this concept but since I adjust the model to a PC I had to ample improvise anyway
    The goal is to combine the model with modern hardware without changing the appearance.
    As some may already know I have the same at the German Casemodding championship
    the first place occupies even though the work is not even completely completed.
    So here is the pre-release.
    I think it will still be exciting and I hope you like the worklog.
    Hardware
    CPU:Intel Pentium G4560
    Mainboard: Asus ROG Strix Z270E Gaming
    VGA: Asus ROG Strix GTX1070 OC Gaming
    Ram: Crucial Ballistix Tactical 16Gb Kit DDR4-3000
    M.2 SSD: Crucial MX300 525Gb
    PSU: Enermax Revolution SFX 550W
    Fan: Enermax TB-Silence 12cm
    watercooling
    CPU: Aquacomputer cuplex kryos NEXT VISION PVD/Nickel
    VGA: EK FC-1080 Strix
    Res: 2 x Aquacomputer Aquatube Delrin black
    Rad: Aquacomputer airplex XT 240
    Pump: 2 x Laing DDC 1T plus with Aquacover DDC
    Flow: Aquacomputer flowsensor high flow for aquaero, aquastream XT ultra and poweradjust
    Displays: Aquacomputer VISION Touch with extern USB-cable, IR and Ambient temperature measurement
    Fittings: CoolForce by Nanoxia
    Liquid: Coolforce CF No.1 yellow
    Accessories and material
    Nanoxia 3Pin, 4Pin, PWM and Mainboard Extensions
    3mm LEDs konkav in white and blue
    toggle switch
    IR dimmer
    MDF, multiplex, plexiglass, aluminum
    BMW Angle Eyes yellow
    Aluminum and plastic priming and adhesion
    wood Sealer
    Paints in silver and anthracite
    textured paint
    Thermoforming film
    Cylinder and Lid head screws
    A big thank you goes to all sponsors without their help me the implementation would not have been possible:
    Nanoxia
    Asus
    Crucial
    Ballistix
    Enermax
    duHu likes this.
  2. ronny78
    ronny78 Member
    13 Aug 2015
    So here is the first update:
    I have tried to document all the work but when looking at the photos I see many details that were not properly photographed.but I hope the photos speak for themselves.
    At the moment I have 260 pictures ;) :p
    First a board cut in the shape of the weapon
    then the essay above and below the middle barrel
    now two ridges around the barrel to its extent to broaden.
    The groove is sawn with the circular saw to install all cables of the LEDs later
    now the first details
    and then two strips for the sides of the barrel
    Now I broadened the upper and lower barrel by another 5mm. The upper barrel I saw but later completely and build it from Plexiglas
    Now the first essays for the estuary. A groove is set with the top cutter
    and then sawn in the correct length
    and sandet in shape
    Now two MDF boards glued together
    and with the grooving cutter the width of the lower barrel milled out. Then cut into shape and ground.
    Now the next parts for this area
    Now the first aluminum parts
    Here the handle on the lower barrel is now provided with long holes and then bent
    And here are the covers of the essays from the barrel
    This was already the first update, in the next I start with the upper barral and thus the first Plexiglas work :)
    Dietec and jones-965 like this.
  3. Cheapskate
    13 May 2007
    Pic links are broke for me. :(
  4. ronny78
    ronny78 Member
    13 Aug 2015
    Can you see them now? I test a new hoster.:eyebrow:
    Time for the next update.
    This time it went to the upper barrel, a lot of Plexiglas was cut, bent and glued with Acrifix.
    and the last two parts of the mouth
    Now the round elements for the reservoir
    If ask is please just ask;)
    Next time it goes with the AGB holders and it goes to the glass parts in the course which are later illuminated.​
  5. ronny78
    ronny78 Member
    13 Aug 2015
    This time a bit later but a slightly bigger update.
    I spare you this time with my technical English, it probably does not make any sense anyway
    Then, until next update :-D​
    Dot_Kappa and jones-965 like this.
  6. DÈF¥âÑt¸.·´¯`¤
    DÈF¥âÑt¸.·´¯`¤ Active Member
    14 Sep 2004
    Perspex and MDF this is my kinda mod! Some nice skills on show :dremel::clap:
  7. kim
    kim Active Member
    10 Jan 2016
    I love your science fiction parts factory
  8. ronny78
    ronny78 Member
    13 Aug 2015
    Thanks guys!
    So you can see all the pictures?
    Continue to the beat.
    Next, the searcher front of the magazine
    :-D
    More rings made of MDF
    The carrier is made of POM
    then the Mainboard Tray.
    2mm Alu
    Okay :p
    Until next time :-D​
  9. ronny78
    ronny78 Member
    13 Aug 2015
    Go on,
    this time unfortunately no particularly good series of photos
    but the little things are just the project to do what it is.
    the MB Tray
    glued with Sikaflex chassis glue
    and now it went to the magazine, the cover for the radiator and the power supply
    So what is missing now?
    The handle and
    the upper cover of the carabiner.
    Okay next time is about the top cover..​
  10. DÈF¥âÑt¸.·´¯`¤
    14 Sep 2004
    Looking great ronny pics are working fine. Amazing work :rock::rock:
  11. ronny78
    ronny78 Member
    13 Aug 2015
    Hi,
    it's time again, my weekly update.
    At some point it had to be done, the water cooler on the VGA mount
    then I needed a bracket for the magazine, 4 x 22mm MDF cubes
    the mount for the riser cable
    Monitors can also be connected via an angled HDMI adapter
    now the top Cover
    5mm Plexi cut and bend
    glued with Akrifix R192
    more Plexi in 3mm.
    CPU - side
    VGA - side
    Pity with the 25 picture limit in some forums but they were already again.
    Then, I hope it was something teaching or not, next time it goes to the construction for the handle and the power supply.​
  12. ronny78
    ronny78 Member
    13 Aug 2015
    Hi,
    now the handle.
    For this I chose Multiplex,
    a groove for the cable from the trigger
    :mrgreen:
    now I have made the grip by deep drawing.
    the trigger
    left side the final shape from the trigger
    more 3mm and 5mm MDF
    The final shape looks good but there is still a lot of details.
    More in the next update
    regards Capten​
  13. ronny78
    ronny78 Member
    13 Aug 2015
    Heyho !
    now i Need extern usb ports
    for the cable
    these alu parts have made me really ready
    bevor the paint job i set all holes for the tubes
    Loop complete,
    how you can see, you see nothing XD
    holder for the res
    Here the panel in front of the handle, so you can not look behind the motherboard or the VGA.
    Left a copy of the Northbridge cooler, for more symmetry in the rear area.
    the psu area
    more mdf covers
    the holes for the eps cable
    two old cabinet handles are exactly fitting
    these contours I created with key files
    The cable protection hoses are fixed everywhere with single-ear clamps and some aluminum has been adapted as veneer.
    for the other side two 8mm MDF stripes
    Power for the psu
    only now have I glued the handle to the gun
    an 8mm dowel for the good conscience
    How do you get a bent wire straight again?
    1. Cut the required length
    2.Fold the ends to better grasp them
    3. Screw the other end into a vice.
    Rule of thumb: turn the wire around its own axis per meter 6-8 times.
    Next comes the paint and the electrics
    Thank you for reading or viewing pictures.
    Until next time!
    :clap::clap::clap:
  14. kim
    kim Active Member
    10 Jan 2016
    :jawdrop:so many details, outstanding accuracy, I spent like 2 hours watching on your pics:thumb:
    ronny78 likes this.
  15. ronny78
    ronny78 Member
    13 Aug 2015
    Hi,
    sorry for being to late but I was a little bit sick.
    As promised the paint Job.
    To get rid of the wood grain I painted it twice with this one.
    Call it Plastic seal but it's like clear coat.
    the colors used
    over 100 parts
    I have coated these parts with textured paint
    Now all individually painted parts were joined together with chassis glue (Sikaflex)
    the electrical part
    3mm LED White konkav
    small details I pushed out
    two inlays of satined Plexiglas, for Standby and HDD Led
    All openings I have deposited with foam rubber
    the 8Pin EPS cable
    then the PW SW buttons and the standby and HDD LEDs
    and here the position of the buttons
    thats the status before the DCMM,after that I changed some little things.
    But the last ones work next time.
  16. kim
    kim Active Member
    10 Jan 2016
    :jawdrop::jawdrop::jawdrop:
    ronny78 likes this.
  17. ronny78
    ronny78 Member
    13 Aug 2015
    Hello,
    Now the last update
    We remember, the stat at Gamescom
    but there were still little things in which I just did not know how to implement them
    1.right, the ornaments behind the mouth
    2.middle, the yellow clips on the barrel and
    3.left, the clips on the reservoir
    first 2.
    i cut out yellow acrylic but after remove the foil it looks like a Little bit green
    so i must paint it in sulfur yellow
    I've cut narrow strips off an aluminum U-profile
    I made a few more and took the most beautiful ones
    that looks good
    now 3.
    the Clips from res. I test a liitle bit with wood but in aluminum it Looks better.
    :p
    Now I have glued the clips with silicones on the barrel
    than 1.
    as you can see on the last picture,the textured paint has no good Quality.
    I must paint it again
    so now the last, left the silver door handles on the Vision Display had to be made of 1mm Alu
    and on the right the frame of the handle I have painted in silver
    So that's it, I can carve a notch more on the door frame again: mrgreen:
    For the sake of clarity, all final images then in a separate post,
    probably also this week.
    Thank you for looking!
    Greetings CapTen​
    duHu likes this.
  18. ronny78
    ronny78 Member
    13 Aug 2015
    And here they are, all the final pictures.
    Have fun! ;)
    duHu and dirkkramer9 like this.
  19. jones-965
    jones-965 Modding & tuning
    13 Jul 2011
    Perfect work, congrats bro! :clap:
  20. Cheapskate
    13 May 2007
    I got to see this while at my Sister's place. MOST of the pics loaded. :lol:
    It came out fantastic. You've done an awesome job with all the tiny details.
