Motherboards ROG STRIX X470-I Question
Discussion in 'Hardware' started by nimbu, 20 Dec 2021.
  1. nimbu
    nimbu Modder
    28 Nov 2002
    Hey Guys,
    On the off chance someone might know. I have the above board and am planning an upgrade to a 5700G
    Now previously APU (2 series) the m2 configuration was one sata and one nvme, what I wanted to know is if I upgrade to the 5700G will both m2's support nvme drives?
    Any ideas?
  2. nimbu
    nimbu Modder
    28 Nov 2002
    Ok being an idiot:
    So it will either be a case it will work with both or wont. Doesnt list 3rd Gen.
  3. sandys
    sandys Multimodder
    26 Mar 2006
    The later APUs, the 4xxx and 5xxx give you more PCIe lanes, so should be on par with 3rd gen full fat chips where you can use all the slots, the 2 and 3xxx APUs will give you reduced motherboard options. if your board supports the new chips it should give you full functionality akin to a proper 3xxx.
  4. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    I'm gonna go with no as the 2nd slot probably won't be wired to allow NVME.
  5. Mr_Mistoffelees
    Mr_Mistoffelees The Bit-Tech Cat.
    26 Aug 2014
    Specs on Asus website clearly indicate only 1 M2 slot supports PCI-E 3, the other is SATA only.
