Modding rom bay door
Discussion in 'Modding' started by j_bro_44, 13 Jan 2005.
  1. j_bro_44
    j_bro_44 What's a Dremel?
    13 Jan 2005
    does any body know how to make a cover for a cd rom bay ?
  2. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    erm :search: or google... there must be loads of people out there to show you.
    oh and welcome to bit.
    -J
  3. skyrex
    skyrex What's a Dremel?
    22 Dec 2003
    if u mean a stealth cover for the actual drive so it appears to mot be there then just get the good ol' dbl sided tape out and smack some of that between the face place and the rom tray edge... *will require some filing/dremmeling of face plate clips first tho. :)
  4. monkeyville
    monkeyville Evilish Monkey ++;
    3 Aug 2003
    Type "Stealth Drive Bay" into the search and you'll get 1001 ways of how to do it
  5. AngelOfRage
    AngelOfRage Minimodder
    8 Dec 2004
    as in a flip down door? you mean something like this?
    its got just a port bay behind it at the moment but im thinking about putting a fan controller in there. nice and hidden...
  6. Wrigley1
    Wrigley1 What's a Dremel?
    5 Dec 2004
    @AngelofRage: I would like to know how to do that, unless you bought it which it kind of looks like but whatever. BTW, that flips up.
    I would think it would be easier to buy a cd-rom bay cover rather than make one. It isn't one of those things i would take pride in making either... "look at these |337 drive bay covers I made dude..." yeah it really just isn't impressive.
