Networks Router + blocked sites
Discussion in 'Hardware' started by seebul, 4 Dec 2005.
  1. seebul
    seebul Minimodder
    9 Aug 2005
    Hi, ive got a netgear router and im using it to block some sites so that my little sis cant go on them on her pc upstairs, it says in the options that i can allow unrestriced access to the internet through one computer, which i want to do with mine, but i have to enter the IP address of this certain PC, how do u find it out? its not the same as the ip adress i have whne i connect to the internet is it?
  2. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    No it's not the internet IP address but the local machine's.
    Click START --> CMD --> then type ipconfig /all
    Then read the part that says IP Adress, it should be something like 192.168.0.2
  3. Firehed
    15 Feb 2004
    And just FYI, that unrestricted setting is probably the demilitarized zone, which basically says 'screw the firewall, let me online'. Which probably isn't the best idea (totally exposed to hackers, etc). Though it's probably the only way to get around the filters, if my router is anything to go by.
  4. seebul
    seebul Minimodder
    9 Aug 2005
    ok cheers guy's it sorted now. :thumb: :D
    oh, also does any1 know of any software that will let me view what all the other PCS connected to my router are viewing? anything free? :D :thumb:
  5. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    RealVNC or my prefference ScanVNC
  6. seebul
    seebul Minimodder
    9 Aug 2005
    thanks mate ill give them a try.
  7. Majormonkey
    Majormonkey What's a Dremel?
    19 Sep 2005
    You will also need to make sure both machines are not assigned dynamic ip addresses from the routers DHCP server.
  8. gbeeby
    gbeeby What's a Dremel?
    6 Dec 2005
    most netgear routers have a table of which machines are connected to the router at that time in the config panel
