Router Brands. Please vote!
Discussion in 'Hardware' started by NzC, 30 Apr 2004.
Which brand of wireless router do you suggest.
  1. D-Link
    30 vote(s)
    26.5%
  2. Linksys
    31 vote(s)
    27.4%
  3. Netgear
    32 vote(s)
    28.3%
  4. Other (post)
    20 vote(s)
    17.7%
  1. NzC
    NzC What's a Dremel?
    7 Sep 2003
    Hey I want to get a new wireless router + switch. Which brand above would you suggest. If something else, please post!
    Thanks!
  2. Murdoc
    Murdoc Gas Mask..ZOMG
    25 Jul 2003
    i have a DG834G it rocks :rock:
    'doc
  3. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    I like D-Link myself. We have one hear at work. Sitting on top of my monitor as well. But I also like NetGear. hmmmm... one of those would be good. As long as you get one that can specifically allow certain computers with a given mac address. That way you can prevent them wardrivers from stealin your internet ;)
  4. aaronrkelly
    aaronrkelly What's a Dremel?
    1 Jan 2004
    Ive had a Dlink and a Linksys router both as well as my current router. I did a flash of the firmware when I first got it and its been up ever since without any restarts, lockups etc. You would never believe its a Microsoft product would ya.
    Microsoft Wireless Router - dont remeber the model number but its a cheapy 802.11b model. The router with the card for my lappy was in kit form from OfficeMax and ran about $135ish dollars. Literally took me 30 mins at most to get the whole thing running. Works like a charm.
  5. [cibyr]
    [cibyr] Sometimes posts here
    30 Nov 2003
    I have netgear Wireless shiz (their 4-port AP + 2x 802.11g pci cards) and they work great. Wouldn't/didn't go dlink becuase my ADSL router/modem kept crashing (which is why I went with a AP that included a router - put the dlink into bridge mode and havn't looked back :) )
  6. buzzy
    buzzy What's a Dremel?
    27 Dec 2003
    I've got a Netgear DG834 DSL modem + router + 4 port 10/100 switch. It's very good at being a basic DSL router, but it's rather limited if you want to do anything non-standard with it.
    For example, I found out the hard way that it's inbuilt DNS server doesn't handle DNS queries for anything other than A records. This is fine for surfing the net, but if you want to run your own mail server behind the NetGear, it can't use the NetGear as the DNS server. There's no way to specify any options in the DHCP scope, so if you wanted to specify different DNS servers, or a WINS server, you'd be out of luck.
    For the standard home user, it's adequate, and the -G model comes with wireless for not a lot extra, which is nice. For the power user: use a Linux box with a DSL modem, it'll give you the added power and flexibility.
    Buzzy
  7. coorz
    coorz Miffed
    25 Apr 2003
    Can't go wrong with any brand nowadays, they all can do the job. Unless you need some exotic feature or absolute total control. Netgear and Linksys being in the more expensive regions normally.
  8. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    i've always went with Linksys and had no problems with it at all, currently got a wireless router and a wirless PCMICA (what ever combination of letters it is) card and none have ever not worked, even though i oce stood on the card n it went 'crack'.
    Though i did choose Linksys because its a division of Cisco and they are the dogs dangley!!!
  9. a9on87
    a9on87 ...
    2 Nov 2003
    I have a D-link wireless set up and haven't had any problems with it. But like said earlier most brands will do the job perfectly fine.
  10. Olly
    Olly What's a Dremel?
    21 Mar 2003
    Zyxel routers - They're excellent, had one for three years, never had a problem.
    Olly :D
  11. batsman
    batsman the quiet one
    14 Nov 2001
    ew talking router 'router' or dsl/cable modem + router?
    i've a belkin router (no modem) that works very well and had no real problems with it.
  12. Hwulex
    Hwulex What's a Dremel?
    1 Feb 2002
    Solwise.
    My SAR-715 is awesome.
  13. kenco_uk
    28 Nov 2003
    I have a Bosch. Black and Decker are good as well.
    *whisper whisper*
    Aaahhh. Well in that case, I have a D-Link.
  14. Ubermich
    Ubermich He did it!
    21 Jun 2002
    I used to have a linksys... it started randomly cutting out, dropping the LAN (though it would stay connected to the cable modem)... I finally got tired of it, started up update the firmware... and it dropped the LAN while it was uploading... = dead router...
    My friend's linksys did the *exact* same thing...
    We've both switched to d-link and neither of us have had a problem...
    Haven't tried the netgear though...
  15. Hwulex
    1 Feb 2002
    That's why I go the Solwise because if that ever happens, I still have the RS232 as backup. :)
  16. ArmyAnt
    ArmyAnt What's a Dremel?
    6 May 2004
    ive had em' all, wrote reviews on thebroken before it went down, and IMHO, dlink is to unoffical, linksys has poor products but great tech, and netgear is best all around. For laptop cards though, definately go with Orinocco.
  17. star882
    star882 What's a Dremel?
    19 Mar 2003
    Cisco :thumb: :rock:
  18. Enak
    Enak Also known as Kane
    23 Jul 2002
    3com 3CRWE754G currently available as a bundle with wireless card.
  19. mushky
    mushky gimme snails
    24 Mar 2003
    In my experience:
    3com rock,
    cisco are the daddy,
    netgear value for money
    d-link look nice but die.
  20. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    3com if you can afford it...
